Thread: IAC valve?
    Regular Member monkeez's Avatar
    Apr 2008
    North East
    Default IAC valve?
    My wife has a Suzuki Grand Vitara and it has a problem that it cuts out when slowing down.
    After hunting around on the net, it seems to be quite a common problem with these cars and it looks like the IAC (idle air control) valve needs cleaning.
    One site suggested cleaning the throttle airways with carb cleaner - but not sure if thats the answer.
    Has anyone any ideas on what to clean the IAC valve with ?
    cheers
    Mileage : 000
    My wifes Vectra B had the same problem. I was able to clean the air valve, with carb cleaner, there was a small hole in the side (inside) of the throttle body, I managed to spray the cleaner in, it did the trick for a while. The best cleaning method is to remove it if you can though. But in the end I had to replace the air control valve as the " valve return spring" had gone weak and did not function proporly. But yes do try the carb cleaner first.
    Apr 2008
    North East
    Ive had the valve off to check that it still works - and it does (turn engine over and it moves).
    They are really pricey things to buy tho £150+.
    So i'll give the carb cleaner ago.
    Is it best to have the engine running when spraying it?
    Mileage : 000
    I think you will find the engine will stall if you spray it whilst it is running unless you hold the throttle open a bit. I would try both. Spray it into the air valve, then start the engine after a few moments, then start the engine and hold the throttle open a little and spray it into the small hole in the side of the throtle body, you will need to remove the air intake pipe from the throttle body first though ( the engine may stall with out the pipe on too). I did all this to the Vectra B. But it still needed a new valve. your quoted price sounds about right too.
    Apr 2008
    North East
    cheers Ed, i'll give it a go.
  1. Brake servo Valve (one way valve)
  2. Replies: 6
    Last Post: 29th July 2012, 13:52
  3. Egr valve, swirl valve problems etc..
  4. EGR valve / Swirl valve
    By SwavGav85 in forum Engine & Drivetrain
    Last Post: 5th January 2009, 17:17
  5. EGR valve and Swirl Valve
    By TUX-VECTRA in forum Vectra C / Signum Troubleshooting
    Last Post: 6th July 2007, 00:43
idle air control valve iacv vectra zc 3.2
