Thread: Hmmm....Insurance
    Hull
    Default Hmmm....Insurance
    Been thinking recently about the vectra rear brake thing (about how quick they wear out) and decided when they need replacing I might just go all out and replace the whole lot for a full set of EBC ultimax brakes with 'green stuff' pads. Technically this makes my car 'modified', so are my insurance company going to charge me the same as chavboy with his focus covered in flashing led's and a bit of drainpipe for an exhaust?
    Regular Member Andy17899's Avatar
    Jun 2007
    West Midlands
    Vehicle : Vauxhall Vectra SRI XPII
    Mileage : 68K
    Just call them, and notify them that you have been advised by a m echanic to upgrade the brakes. I really cannot see it being an issue mate
    Winteringham
    put larger disks all round on my vectra and K&N phoned insurance and price went down by £50 result, got told if no K&N would have got bigger saving,
    Jul 2006
    If you are just using aftermarket pads & discs, then no need to tell the insurance. There's no difference between using EBC Green stuff and the el cheapo pattern fit parts from your local motor factor.
    You only need to tell them if you change the sizes of the discs.
    HTH
    Jun 2007
    West Midlands
    Mileage : 68K
    As above, thought it said you are putting bigger disks on.
    If your changing the brakes, and is just a different brand, then its not a modification.
    Andy
    Hull
    Just checked, and the discs are 285 front and 278 rear, which I think is the same as the originals. Just the ultimax are designated 'sport slotted'.
    Maida Vale
    Quote Originally Posted by carteg View Post
    Have you just got the K&N panel filter or the induction kit? If it's just the panel filter then there was no way your insurers would ever have found out it about other than you telling them - no insurance engineer visiting a damaged car at a bodyshop to agree costs, or at a salvage yard to calculate the market value, is ever going to bother opening the airbox to see what's lurking inside. Hats off to you for honesty, but most people wouldn't have mentioned it and would get away with it no problem.
  1. hmmm have look at this what you think
    By vectra sri dan in forum Vectra C / Signum Car Chat
    Last Post: 1st April 2011, 13:17
  2. Hmmm - Should I or shouldn't I...
    By Penfold101 in forum Vectra C / Signum Car Chat
    Last Post: 1st July 2008, 12:56
  3. Hmmm......
    By Deadman in forum General Chat
    Last Post: 25th September 2007, 18:34
  4. hmmm
    By parapaul in forum Signature & Avatar Testing
    Last Post: 1st October 2006, 13:49
