Results 1 to 10 of 11
Thread: backplate behind brakes
    Regular Member vectragsi3.2's Avatar
    Feb 2007
    cheshire/staffordshire
    Default backplate behind brakes
    hi all just wondered if i remove the wheel will i see the backplate behind the discs so i can eliminate this as i have a metal noise coming from the front area on new brakes and discs hope this makes sense??
    Regular Member poves's Avatar
    lancashire
    it will be the back plates rubbing against the rear of the disk , I had this lol , they move easily when your handling the calipers etc : ) .
    So yes just remove wheel and you should see the problem.
    Regular Member shan's Avatar
    I think they will just need bending back a little. " dust guards "
    lancashire
    Quote Originally Posted by shan View Post
    I don't think there is a back plate on the front's. " dust guards "
    It's like a shim plate , I had the excact same issue after I did me brakes , Wat a wolly .
    Feb 2007
    so will i see it straight away? will i see something touching at the back? would rather do it myself than someone charge me money for just bending a bit of metal back
    lancashire
    yes it will be obvious mate. 5 mins to sort. I did my brakes in bad light and by the time I got everything back together it was dark , I had a bad scraping grating noise when driving , day after I took wheel off and looked behind disk and the plate was touching.
    Feb 2007
    is it definately a wheel off job?
    lancashire
    You may get at it with full lock on steering just have a look.
    Feb 2007
    cheers mate so just to clarify alls i need to do is just bend a piece of metal away from the disc and that should cure it?
    lancashire
    Hopefully mate , sounds like the excact same issue I had , let us know how you go on .
  1. Replies: 14
    Last Post: 3rd September 2011, 20:23
  2. brakes
    By hairy31 in forum Handling & Braking
    Last Post: 26th February 2010, 18:25
  3. rear interior light with backplate for sale
    By poves in forum Parts for sale
    Last Post: 24th February 2009, 23:35
  4. brakes
    By vecsxi in forum Vectra C / Signum Car Chat
    Last Post: 8th March 2008, 00:55
