Results 1 to 10 of 18
Thread: Track rods\Ball joints or both?
    Regular Member joules2.0t's Avatar
    surrey
    Trim : SRI
    Year : 53
    Default Track rods\Ball joints or both?
    Right Gents I am sure someone has the answer here.
    Had the wheels aligned about 5 months ago, and all has been fines until recently. The steering seems to want to pull to the left slightly – slightly off of the 12.00 mark. The steering also seems to wonder sometimes and tracks the roads a lot more than it used too??
    Also sometimes turning left I can feel something sort of move or tap through the steering wheel - Track rods\ball joints?
    Checked tyre pressures at front and all fine both sides are the same.
    Can it be worn track rod ends or the ball joints making the steering feel like this?
    Cheers lads.
    Joules
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    sounds like the track rod end or it also can be the tie rod which goes from the t/r/e to the rack as mine was like that when i rebuilt it and it was the tie rod
    surrey
    Trim : SRI
    Year : 53
    Sod all those bloomin speedhumps!!
    Tie rods. Can find em in my Haynes manual. Are they hard to change?
    can be a bit tricky
    surrey
    Trim : SRI
    Year : 53
    Cheers Glynn.
    Will try and pop into a garage tomorrow near work and get em checked.
    Is it worth changing both the rod ends and balls at the same time as the tie rods as it will be in bits anyway?
    Are we talking loads a money for the parts...
    Quote Originally Posted by joules2.0t View Post
    Cheers Glynn.
    here is one on ebay http://cgi.ebay.co.uk/VAUXHALL-VECTR...3286.m20.l1116
    but they are about £20 for the complete kit at the dealers
    surrey
    Trim : SRI
    Year : 53
    Nice one Glynn. At least I now know what to look for.
    Will get em checked tomorrow.
    the big nut end in the link is hiden behind the rack gaitor if that helps you out
    surrey
    Trim : SRI
    Year : 53
    Yep sure does mate!
    Thanks again.
    surrey
    Trim : SRI
    Year : 53
    Just thought I would update this post.
    Nipped into the garage early this morning, They checked all the mentioned parts and said - all OK.
    Can you visually inspect the Tie rods without removing the gataior???
    Checked the tracking and front was out only slightly so re-adjusted to the tune of 35 notes.
    The bloke commented on how nice the exhaust system was and how well fitted it was also. Brought a smile to my face.....
    So far slight improvement, not sure how much is just me "thinking" something is wrong - Will check it again, especially the tie rods, when I change the alternator pulley with some mates.
  1. track and tie rods
    Last Post: 26th September 2011, 23:59
  2. Track Rods
    By biggsa in forum Suspension, Wheels & Brakes
    Last Post: 4th June 2010, 20:27
  3. Track Rod Ends or Inner Track Rods
    By Padster72 in forum Suspension, Wheels & Brakes
    Last Post: 28th April 2010, 11:41
  4. Ball Joints
    By xaviroller in forum Suspension, Wheels & Brakes
    Last Post: 26th June 2009, 20:10
