Results 1 to 10 of 13
Thread: Spark Plug change
    Regular Member old cruiser's Avatar
    slough
    Default Spark Plug change
    Just cleaned out throttle body, EGR Valve , changed air filter, fuel filter and spark plugs, all were in a bit of a state to be honest apart from the throttle body which was surprisingly clean! anyway what I noticed was, when fitting the coil pack back on after fitting plugs (2.2, Z22SE engine) , there didn't seem to be a real way of ensuring that the long rubber plug caps (if you know what I mean) were actually clipping on to the plugs as it were, just had to rely on doing up the four bolts and hoping for proper connection on to the plugs, however the car runs fine, but anyone else found this when changing the plugs?
    Cheers Pete
    Regular Member danlat1415's Avatar
    Lancashire
    Just curious, how do you change the fuel filter?
    Also are the spark plugs easy to get to, and to you need special tool to get them out?
    My Vectra seems to have gone a bit sluggish over last few months, and it's due a service (which I usually do) I changed everything on it, butI've never changed a fuel filter or spark plugs before.
    Any advise will be greatly appreciated.
    Also... is it easy to replace/or clean the EGR valve?
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    danlat, if its a 2.2 petrol you can just blank it off. (the EGR that is)
    Lancashire
    it's a 1.8 petrol...?
    Vehicle : SRi
    Mileage : 137000
    Sorry then mate, no idea?
    Quote Originally Posted by danlat1415 View Post
    fuel filter... behind the drivers side rear wheel.. under the floor..the cannister is slipped in a plastic ring to retain it.. the fuel lines are secrured with two feindish clips that can be a swine even with the proper tool to release them..
    spark plugs are under the plastci engine cover.. remove that first ( two bolts)
    the coilpack is in the middle of the top of the engine, remove the securing bolts and the multiplug on the end. pull up to release the coilpack..
    you will now have 4 'holes' with the plugs at the bottom.. these 'holes' should be oil free..
    use a long extension and a '10mm' compact sparkplug socket and replace each in turn..then replace all you removed..
    Lancashire
    Thanks for that guys.
    Sorry to hijack the thread...
    GSI3.2 - Do I need to empty the fuel before I change the filter, or would a bucket and quick hands be enough?
    Also, you know anything about the EGR Vaule on the 1.8? Is there one, and is it a replaceable part, or would it just need a clean?
    Dan
    you will only drop about a mug full of fuel..thats all.. just do it when the car has sat for a while so it's de pressurised...
    the 1.8 EGR valve is a very reliable item and i'd be amazed if it needs cleaning at all.. they don't suffer sooting anything like the 1.9's and 3.0's as there is simply less 'muck' in the exhaust...
    i have replaced them due to failure of the solenoid, but never because they were clogged up.... i'd leave it well alone..
    New Member Chedder's Avatar
    Birkenhead
    Default Getting at spark plugs
    Just about to change plugs, and OMG where are the HT leads nowadays!
    Reading above post, it looks like I have to remove the engine cover, then unbolt the coilpack - presume this is the black piece that runs across the top of the engine - this unbolts easily enough but seems to be quite firmly in place - is it ok to give it a firm tug to get it off?
    Darlington
    Quote Originally Posted by Chedder View Post
    No HT Leads anymore - replaced by coil packs
    I would assume so, but DO NOT take my word for it, someone who is a lot more helpful and knowledgeable will be along to advise properly.
  1. spark plug change.
    By paz_badboy4life in forum Engine & Drivetrain
    Last Post: 3rd October 2011, 01:31
  2. Spark plug change help
    By Lee_gsi in forum Vectra C / Signum Car Chat
    Last Post: 29th July 2011, 15:12
  3. Spark plug change on 2.2
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 24th March 2009, 03:56
  4. 3.2 V6 Spark plug change
    By korlinski in forum Vectra C / Signum Car Chat
    Last Post: 5th June 2007, 14:19
  5. 3.2 Spark Plug Change Help
    Last Post: 11th May 2007, 14:29
signum 1.9 spark plugs
vauxhall vectra 2005 spark plugs replacement
2004 1.8 vauxhall vectra spark plugs replacement
2005 VECTRA REPLACING THE SPARK PLUGS
holden vectra zc 3.2 spark plug replacement
replace spark plugs on vectra c 2.2 direct
fitting vauxhall vectra 3.2 v6 spark plugs
plug change 2005 vectra
vectra sri 2.2 spark plug remove
how to change spark plugs in vectra 3.2
vectra zc spark plugs change
how to change spark plugs vauxhall vectra
vauxhall vectra series B 16v petrol sparkplug type1.8ltr thread dia
coil pack bolts on a 2005 vauxhall vectra
vauxhall vectra b 1.8 sri spark plug removal
how to change spark plugs vectra 3.2
signum 1.8 petrol spark plug fitting guide
change spark plugs vectra c 2.2
vectra spark plugs change
correct spark plugs for vectra sri 1.8
vectra c spark plug change
vauxhall 1. 2 rubber sparkplug
vectra 3.2 v6 coil pack change
vectra c 2.2 direct spark plug removal tool
