Thread: New Front & Rear Brakes
    Winteringham
    Default New Front & Rear Brakes
    I did the front and rear brake upgrades yesterday with the help of my mate Mark, the fronts went on very easy and look great, but the rears were a pain I got the upgrade kit from LMF and could not fit the pad's!!!
    desided to fit one of the old rear with one of the new pads I know not the best but did not want to grind them down.
    Can I get new rear calipers that will fit the correct pads in? or are there different pads that I need to get. I got all of the brake pads and disks from LMF.
    Regular Member phil67's Avatar
    Nottinghamshire
    Vehicle : Vauxhall
    Trim : Exclusive
    Engine : 1.8
    I had the same problem matey, so ended up getting some new calipers for a 3.0td and fitted them the week end, pics were taken but plasma has them on his phone.
    Winteringham
    how much are the calippers and were did you get them from?
    all vectra-c rear pads are the same size and style...
    all that differs is the spring clips on them and the compound between OEM and aftermarket pads.
    Maida Vale
    Did you retract the cylinder to make room for the new/thicker pad?
    Winteringham
    yes got the piston rewind tool and still would not fit so going to be getting 3.0 calipers when i get part number and price
    Regular Member simon1's Avatar
    Oct 2007
    Leicester
    Vehicle : Insignia elite tourer vxline biturbo
    Trim : Elite vxline
    Engine : 2.0 biturbo
    Mileage : 80000
    wasl ooking at doing this mod too. and have been told you have to sand new pads down if using the std calipers as proper ones are wider to allow for vented disc thickness.
    how much did the rears set you back from lmf , if you dont mind me asking
    Jul 2006
    The other option is use your part worn pads with the new discs, they should fit OK. The by the time the pads need changing, the discs will be worn enough that you can fit new pads in there...
  1. Front and rear brakes
    Last Post: 26th February 2012, 22:16
  2. Front and rear brakes
    By davidlewis24 in forum Vectra C / Signum Car Chat
    Last Post: 1st August 2011, 13:15
  3. vectra vxr front and rear brakes
    By tbs in forum Suspension, Wheels & Brakes
    Last Post: 10th March 2009, 22:43
  4. gsi front and rear brakes.
    By hagga in forum Parts for sale
    Last Post: 14th February 2009, 15:32
