Thread: DMF - Dual Mass Flywheel
    May 2008
    maidstone
    Default DMF - Dual Mass Flywheel
    I have to get mine changed next week under Network Q warranty.
    Is it a big job?
    What is the DMF? and what does it do?
    Why would it need changing?
    Cheers!
    Wittsy
    it's the dual mass flywheel....they are no longer solid but now made in two parts.. the damping springs between them fail and it rattles and judders like a swine..
    is it a big job?.. yes... subframe out, gearbox out ... not one to do on your back at home...
    Thornton Dale
    Vehicle : Transit Custom
    Trim : Limited
    Engine : 125PS
    I did mine on my own, on my drive, on my back and at home. Even got the dam gearbox back on with no help, that was a sod!
    what i meant was it's not one you'd catch me doing at home.....
    top respect for doing it. ..the boxes can be a git to fit when up in the air let alone when on your back and alone...
    Thornton Dale
    Trim : Limited
    Engine : 125PS
    It really was hard, I didnt think it was going to be possible to get the gearbox back on. All the angles to use your strength are working against you. I had to use my legs and all the strength I had. As you will know, its the weight but also getting the dam thing aligned up to slide in too!
    I also never used a clutch tool! lol
    You will be used to nice working conditions, so I can understand how daunting it sounds to work on a drive. I obviously had no choice.
    dudley
    Hi All
    A colleague at college had his go on his Ford Focus Diesel, the radial spring had weakened allowing over two inches of play between the masses. The thing is we both tow caravans, I was just wondering if this is a factor.
    CS
    Regular Member John C S's Avatar
    May 2007
    Gangsta crossover on the drive? Check
    Quote Originally Posted by CHRISSMART41 View Post
    Hi All
    CS
    I honestly don't think towing a van would cause premature failure, unless you really abuse it IMHO.
    Default DMF - engines ...
    Anyone know if are they fitted to the full range of engines, or are they diesel specific?
    Regular Member benny's Avatar
    Feb 2006
    dudley
    Quote Originally Posted by SYMON View Post
    as said you wouldnt catch me doing one without a ramp or a hot cuppa tea and a bacon sarnie near by ......
    Feb 2006
    dudley
    Quote Originally Posted by John C S View Post
    the material between the two steel parts is made from a rubber compound allow some seriuse heat into the system (from say a sliping clutch) the rubber will melt and the flywheel will rattle / go faulty ..note the 19's have a built in fault so they fail due to the drive haveing a cold ...lol ...
  1. Dual mass flywheel???
    By Vectra Adz in forum Engine & Drivetrain
    Last Post: 12th July 2012, 07:26
  2. Dual Mass Flywheel?
    By Gascon in forum Vectra C / Signum Car Chat
    Last Post: 6th December 2008, 21:44
  3. Dual Mass Flywheel ???
    By diesel dog in forum Engine & Drivetrain
    Last Post: 1st December 2008, 11:33
  4. Dual Mass Flywheel...........again
    By Gaz the Cab in forum Vectra C / Signum Car Chat
    Last Post: 1st July 2008, 22:02
