Results 1 to 10 of 14
Thread: Strange Noise on Start Up From Cold 1.9 CDTi 150
    Edgbaston, Birmingham
    Default Strange Noise on Start Up From Cold 1.9 CDTi 150
    When I start the car up from cold, after an overnight stop, I can hear a strange sound coming from the off side of the engine.
    This cannot be detected from inside the car and is only apparent if you stand next to the car. It is really hard to describe the sound but it's almost like a steam engine hissing sound. It is not continuous, but is very regular intermittent almost clockwork like. It sounds as though something is making a noise when it rotates, but is rotating quite slowly.
    The noise becomes quieter the longer the engine is run and would appear to stop after a few minutes.
    The car is 1.9 SRi CDTi 150 is a 2006 model and has covered 51000, so is quite a way off another service.....but should I be booking it in to be looked at???
    Any ideas ?
    is it coming from down by the airbox area..by the drive belts?...why do you think it's rotating slowly?....
    with all thats down that end of the engine...( water pump, cambelt and idlers, driven accessories) i'd just get it checked out to be sure, rather than have a disaster..
    Oct 2007
    Ripon
    I have a strange noise too on my 1.9 (150) .... not every start but when car has been stood for a while (cold) get a regular noise almost like tock tock tock sort of noise, seems to come from pully side of engine ...... louder on tick over and goes at revs .... once warm nothing. On 64000 miles
    carlisle
    Had the same type of noise on my 1.9 CDTI, they ended up putting a new timing belt and tensioner kit on, problem solved. Took them a while to find it, had to leave the car at the garage three days as it only did it from cold and would disapear after 5 mins.
    Interesting. To be honest I don't really know why i think it's rotating slowly! I guess the time between the noise sounds doesn't necessarily reflect reflect the speed of rotation, or indeed rotation at all!!
    Quote Originally Posted by robdd1 View Post
    Sounds the same,.....very hard to describe a noise in words! My noise is louder on tick over and also nothing when warm.
    Quote Originally Posted by gnomes View Post
    Thanks for the info. At least i can give them some pointers. It did occur to me that once I got to the dealership the noise would have already ceased!
    Regular Member Nev's Avatar
    Gosport - Hampshire
    I'd be thinking it's the bearing going in the cam belt tensioner - had a very similar 'ttsssss'(!) sounding noise on the tensioner on my rover 220 at start up - did belt / tensioner change - no more noise.
    HTH
    Neil. - oh and cheap plug - there is a good 'How 2' with photos for a cam belt change on here!
    Regular Member shane31's Avatar
    Sep 2011
    Staffordshire
    I know this is an old thread but thought i should comment.. As a result of reading this i have had my cam belt and tensioners replaced as i had a swish swish noise on first morning cold start and now the noise has now gone many thanks to all that posted the fix for this and many thanks again to vectra-c forum.
    Regular Member Saf_789's Avatar
    Feb 2011
    BRADFORD
    Ive actually got the same issue. On cold startup it goes "tss tss tss tss tss tss". I figured this was normal on my car as its the first diesel ive owned. I will get the cam belt and tensioners replaced. Out of curiosity, how much did it cost you? Then i know how much i should be paying roughly.
  1. Cold Start - Blowing Noise...
    By dexter69 in forum Engine & Drivetrain
    Last Post: 8th May 2012, 16:07
  2. Strange engine noise on cold start
    By stevied26 in forum Vectra C / Signum Car Chat
    Last Post: 1st September 2010, 19:17
  3. Strange smell when cold 1.9 cdti
    By sri22dti in forum Vectra C / Signum Troubleshooting
    Last Post: 16th April 2007, 12:06
  4. CDTi 16V Cold Start
    By denzo in forum Vectra C / Signum Car Chat
    Last Post: 6th August 2005, 11:19
Vauxhall Insignia diesel noisy start up is it normal
vauxhall insignia 2011 noise when engine is cold
vauxhall insignia knocking noise when starting up from cold
fan tensioner noise in insignia 2010 cdti
my desiesal vectra is noisy when ticking over
hissing noise from a180 diesel when cold
diesel makes hissing noise when cold
vauxhall insignia making noise when starting from cold
insignia diesel engine squeal when cold or hot
zafira rattle 5 mins after cold start
zafira belt noise after starting
belt noise on first start insignia
insignia strange noise
insignia cdti rattle when cold
Astra CDTi SRi 150 noisy start
1.9cdti knocking when cold
diesel insignia makes noise when starting up
vauxhall astra noisy when cold
vauxhall makes a tick tock noise on startup
vauxhall vectra 1.9 cdti engine rattle
insignia cold start noise
opel vectra strange noise
zafira b pulley rattle cold engine
insignia strange noise on start up
vauxhall insignia belt noise
