Thread: Clutch/gearbox problems
    Reading
    Default Clutch/gearbox problems
    Hi all,
    I'm getting a horrendous crunching sound from my 1997 vectra arctic. It mostly happens when using the clutch in low gears (junctions etc) and it has happened when stationary (happened loads stationary in a traffic jam yesterday when i was resting my feet). It has also happened when driving in 3rd gear a few times.
    The sound only lasts a second or so and its getting more frequent. Tends to be worse on hot days, and it normally takes at least 10-15 mins worth of driving for the problem to start.
    Vauxhall dealership want £300 just to look at gearbox and a possible further £850 for clutch/gearbox replacements. Given the age of the car, I'm a bit cautious about paying this without finding out more about the problem.
    It had a recent MOT and they couldn't find anything when checking the clutch bearings. From looking at similar forums there is some discussion of clutch drag, replacing gearbox oil, syncos and linkage, clutch plate spring and thrust bearings related to similar problems. Has anyone had any experiences/ know what it is likely to be? And more importantly how much was it to rectify?
    Appreciate your help
    David
    Regular Member DeanF's Avatar
    Nov 2007
    Staffordshire
    Quote Originally Posted by dwetherill2 View Post
    Hi all,
    David
    Are you saying ? (As it is not very clear from your post) That when you Select a Low gear, It is crunching when going into that gear ??
    If so, Has the gearbox oil level been checked ??
    Possible issues.
    Worn clutch./Dmf Flywheel
    Low Oil level.
    Worn Syncro's
    Incorrectly Adjusted Linkage (although this would happen all the time generally & not after getting warm Etc)
    Dean
    Reading
    Thanks dean.
    Well it happens while im in gear. Often when im doing clutch control in slow moving traffic. Dont think its ever happened when changing gear. It even happens when im not in gear.
    So do you know if replacing the syncros would be as expensive as replacing the clutch?
    david
    Regular Member opel_estate's Avatar
    May 2008
    Sweden
    Vehicle : Opel Vectra C Estate
    Trim : Enjoy
    Engine : Z22YH
    Mileage : 35000
    Nov 2007
    Staffordshire
    Thanks dean.
    david
    Syncro's would only give you hassle whilst changing gear, So that rules them out, Do you feel the crunch through the Gear stick or pedal ??
    Dean
    Maida Vale
    Whatever the cause of the problem is, no sense whatsoever in getting a Vauxhall dealer to deal with it - you'll be paying a much higher labour rate for no tangible extra benefit. Any competent high street mechanic can handle clutch replacement, and it it's the gearbox then a transmission specialist would do a better job.
    Regular Member dave16v's Avatar
    Jun 2007
    Scotland
    Vehicle : Ampera, Astra Sri
    Trim : Sri
    Engine : 1.4 hybrid, 2.0 cdti
    out of interest how do you change the gearbox oil ????? or check it
    manual boxes don't really need an oil change , auto's are best changed every 60,000 miles...
    the auto's have an obvious dip stick to check the level and the manuals don't...really the manual is to all intents and purposes a sealed unit and best left alone unless you can spot an obvious leak..
    Regular Member stuartbat's Avatar
    May 2008
    shropshire
    i had a veccy b and had to replace 2 gearboxs in it due to the bottom diff gears being like cheese. Sounds like uve lost a few teeth on 1 of the diffs i had this problem also. the cruching sound is the missing teeth getting further ground up in the diff unfortunalty. ( sorry my spelling crap but its late and im tired)
  1. Vectra C 2.2 DTI Clutch/Gearbox noise problems
    By Gramoz in forum Troubleshooting
    Last Post: 14th August 2012, 14:13
  2. gearbox and clutch
    By vectra craig in forum Engine & Drivetrain
    Last Post: 13th June 2012, 19:50
  3. 06 vectra 1.8 sri clutch/gearbox problems, please advise.
    By 06sri in forum Engine & Drivetrain
    Last Post: 31st May 2012, 16:30
  4. Clutch?? Gearbox??
    By wingz123 in forum Troubleshooting
    Last Post: 27th March 2011, 10:47
  5. New gearbox and clutch
    By 2.2direct-sri in forum Engine & Drivetrain
    Last Post: 21st July 2009, 13:52
06vectra automatic how to check gearbox oil level
