Thread: linksys router help please
    Regular Member deano1's Avatar
    leicester
    Vehicle : Vectra estate
    Trim : Sri xp2
    Engine : 1.9 cdti 150
    Mileage : 100000
    Default linksys router help please
    hi just brought a linksys router of here but didnt get a disc to set it up when i plug it all in and then try to connect it comes up unsecured network how do i put a password into it so no one else can connect my old 1 which is a d-link came with a set up disc which i was able to set up a password i really dont want to use it with no password in.
    thanks dean
    Northampton
    Engine : A20DTH
    Mileage : 88000
    type 192.168.11.1 into you web browser and you should see the setup 4 ur router.
    if that does not work you need to find the default gateway.
    Go to start 2 start-RUN
    Type in CMD into the dialouge box
    Then type in ipconfig /all into the box that opens
    Scroll through the output and you will see the default gateway, use this in your web browser
    Also go to the Linksys website and download the instruction manual
    Regular Member MysteryElite's Avatar
    Feb 2007
    North Somerset
    You will almost certainly be able to log in to the router directly and set up your security options there - most have a management server that work from a browser, although you may need to factory reset if there is already a management password in place.
    First step would be to search on http://www.linksys.com for the model of the router and see if you can download manuals etc from there. This should take you through any configuration step by step.
    Surrey
    Is it wireless? Connect to it through IE with the cable connected to access the admin control panel.
    Regular Member neilshaw1980's Avatar
    Oct 2006
    coventry
    In your browser's address bar type 192.168.1.1
    It should bring up a log on box, if its the first time you have done this then leave the user name field blank and put admin as your password. It should bring up the router settings web page. There you can change the router settings.
    Oct 2006
    coventry
    leicester
    Trim : Sri xp2
    Mileage : 100000
    thanks for the good advice
    ive now manged to set the router up works connected to pc ive put a password into it same as my old routers 1 but my laptop wont connect it finds the network i click connect enter password but it dont connect any ideas much appreciated
    Feb 2007
    North Somerset
    With some routers you can set them to allow connection from only specified MAC addresses - would be worth checking whether this feature has been turned on (also known as a closed client list)
    leicester
    Trim : Sri xp2
    Mileage : 100000
    Quote Originally Posted by MysteryElite View Post
    checked that all ok there finally got it to connect but drops the signal after a few secounds tried diffrent channels but still the same could it be a faulty router.
    Full Member stuart bigboy's Avatar
    May 2007
    kent
    Default router
    hi there its not the router it was working fine when i had it here never lost signal even when i was in the garden must be some settings you have changed
  1. Linksys Cable Broadband Router
    By stuart bigboy in forum General items for sale
    Last Post: 16th July 2008, 17:13
  2. anyone use a router ?
    By rob 2.2dti in forum The 'Off Topic' room
    Last Post: 15th July 2008, 00:31
  3. What router do i need???
    By Auto-Brite in forum General Chat
    Last Post: 24th November 2007, 15:52
  4. Linksys ADSL Gateway Router
    By greeningr in forum General items for sale
    Last Post: 3rd June 2007, 22:12
  5. Replies: 12
    Last Post: 29th November 2006, 10:17
