Results 1 to 10 of 13
Thread: AFL
    Regular Member gsi.vxr's Avatar
    Hertfordshire
    Default AFL
    Anyone know what year AFL was introduced on the Vectra C? I've got headlamp level failure on my Xenons and Vauxhall need to know if my model has it or not for the replacement control unit. For reference I've got a 2003 GSi. Thanks in advance.
    VX can work it out for themselves if they just use your Reg plate and /or VIN number.... did you get the teaboy?..
    Which beds dealer is it?...as you're local...
    in swift answer.. if you headlights TURN with the steering then you have AFL.. if the beams stay pointing straight ahead then you don't.. TBH i really doubt you will have AFL..
    Hertfordshire
    Yea, I was actually using Marshalls in Hitchin, Herts. I think they've got a new member of staff as normally they are very good lol. The lights have never moved when I turn the wheel. I wasn't too sure how noticeable it would be.
    Thanks!
    if they have never moved, then deffo no AFL..
    Hertfordshire
    OK, thanks for the info. Just out of interest would AFL have been an option when my vehicle was new?
    Regular Member Matty H's Avatar
    Bristol
    You need to be moving though (over 10mph I think). They dont turn if the vehicle is stationary.
    I think you'd know if you had it. When you turn the engine on in the dark with the lights on auto you can see the beam dip, then turn inward, then raise and level. They are also very noticeable when turning with the wheel when moving, particularly if you come to a stop behind a car with the wheels turned as the lights suddenly turn back to the front
    Hertfordshire
    Ok, cheers. 99.9% I haven't got AFL then. Wish I did now though, sounds very cool.
    AFL was not available on 2003 models at was only on 2005 model year onwards yours will only be normal xenons .....................Fuggin dealers what a load of toshers !!!!!!!!
    Hertfordshire
    Quote Originally Posted by Drinky View Post
    Thank you. I'll order it now. Cheers
    Regular Member rorycarz's Avatar
    Dec 2005
    AYRSHIRE SCOTLAND
    it wont be the control unit m8 .itll be one of the 4 sensors at each wheel .. this happened to mine .they told me it was the control unit so i replaced the it and guess what still the same .turned out to be wheel centre after many of my £££££.....before taking it to them id check all the headlight conections
