Results 1 to 2 of 2
Thread: Anyone tell me how 2 drain the coolant?????
    edinburgh
    Default Anyone tell me how 2 drain the coolant?????
    I have a 2007 vectra c that I wish to change the coolant, can anyone give me detaled step by step instructions?
    Thanks in advance.
    two ways.. both effective...
    either 1, remove the small drain plug in the lower corner of the radiator to allow the coolant to escape..
    or 2, just remove the bottom hose from the radiator.. this will do exactly the same, but faster....it's only one spring clamp that holds the pipe on..
    if your car is a diesel you'll have to remove the undertray first to do either way...
  1. drain coolant without taking bumper off
    By andy_richmond in forum Vectra C / Signum Troubleshooting
    Last Post: 14th December 2012, 09:43
  2. 1.9CDTI (120) - Coolant drain point
    By snapsnap in forum Engine & Drivetrain
    Last Post: 27th May 2012, 11:56
  3. What can cause a voltage drain...
    By Penfold101 in forum Electrical & ICE (including SatNav)
    Last Post: 29th September 2010, 19:17
  4. Drain Plug - Coolant
    Last Post: 22nd June 2009, 13:53
  5. What's the easiest way to drain the coolant on the GSi ?
    By muffking in forum Vectra C / Signum Car Chat
    Last Post: 3rd December 2006, 19:40
vectra c coolant change
vectra c radiator drain plug
vectra c coolant change site:www.vectra-c.com
vectra c radiator drain plug site:www.vectra-c.com
vauxhall vectra c coolant flush
vectra radiator drain
drain coolant from vauxhall Vectra 2002
how to drain coolant vauxhall vectra
vectra coolant flush
drain coolant vectra
vectra c how to drain radiator
radiator drain plug vectra c
how to flush vectra c coolant
how to drain radiator in vectra c
how to drain the coolant from a vectra c
how do you flush coolant on 06 vectra c
how to flush the coolant on a vectra c
