Thread: Opinions on new suspension and springs
    Regular Member danlat1415's Avatar
    Lancashire
    Question Opinions on new suspension and springs
    I've been meaning to change the suspension on my Vectra now for nearly a year, but things have been getting in the way, but now i've finally got round it.
    I've got a 1.8 SXI (sports suspension as standard)
    What shocks and springs do you guys recommend for a nice comfortable ride?
    I've got 18" alloys with low profiles on, so this with rubbish suspension meansthe ride is pretty terrible at the moment.
    I may replace the arm and links as well just for the sake of it.
    I've got a budget of around £500 for the parts, but the more change I have left, the happier the other half will be
    I've been looking at the Bilstein but don't know which to get, or if anyone recommends anything differenet. And springs to go with them.
    Dan
    Jul 2006
    For your £500...
    Eibach Pro-Kit, £130 from LMF
    Bilstein B4 dampers, £150ish from LMF
    Drop links, £10 from EuroCarParts
    And enough left to take the good lady out for a meal - you gotta keep them sweet!
    Lancashire
    are the Bilstein B4s ok? they seem to be the cheaper of the range. Also, The SXI has the sports suspension same as SRI, so if I put the B4s on, will the ride be higher? or the same..?
    I've also seen these on LMF - very cheap for a full kit:
    Supersport Sprint Suspension Kit - Vectra C - (£258.49 to £270.24)
    http://www.lmfvauxhall.co.uk/store/p...at=2285&page=2
    Any advise guys?
    Here, there and every where!
    If you fit the Eibach's it will lower it around 15-20mm more than a standard SRi set up
    Jul 2006
    B4's are fine... B4 + Eibach = Irmscher setup
    The springs determine the ride height, not the dampers. With Eibach springs fitted the ride height will be slightly lower than the SXi, but the handling improvement is amazing.
    Never heard of Supersport, but if LMF sell it, it's probably OK. It's TUV approved so won't be complete tat anyway
    May 2008
    St.Albans
    Is it worth just getting the springs alone ?
    And what to get Irmscher or Eibach pro ?
    Quote Originally Posted by Impresss View Post
    I did. Eibach's working well
    Ex-Staff Full Member Taffyopel's Avatar
    Oct 2007
    Horley, Surrey
    Fitted Pi Springs to my SRi which brought it down another 15mm on the standard setup and the ride and handling is spot on.
    Snowman, you got your ears on?
    May 2008
    St.Albans
    Quote Originally Posted by Caterman View Post
    Thanks, I take it Eibach's are lower than factory SRI's ?
    May 2008
    St.Albans
    Also I take it its a easy job to fit them ?
  1. Anyone used LO Suspension springs?
    By Coupe2T in forum Suspension, Wheels & Brakes
    Last Post: 2nd April 2012, 20:23
  2. help, need suspension springs
    By mooney in forum Vectra C / Signum Car Chat
    Last Post: 16th August 2008, 22:23
  3. Koni Suspension Springs Kit
    By coopster in forum Handling & Braking
    Last Post: 11th April 2008, 10:32
  4. Koni Suspension Springs Kit
    By coopster in forum Suspension, Wheels & Brakes
    Last Post: 6th April 2008, 00:33
