Results 1 to 10 of 23
Thread: Vibration through car
    Regular Member Orbilator's Avatar
    Fife
    Unhappy Vibration through car
    I getting a Vibration through the whole car, its driving me mad, Do you think its a Wheel balance thing? I tried changeing the tyre pressure from eco mode down to standard and its excactly the same. the car is 9k and i only had it a month, I kinda thinking unbalanced wheel or tracking or maybe misa ligned tyre ?
    It is not a rerally bad Vibration but i can feel it through the steering wheel a little and if i put my hand on the arm rest it a lot more prominent. Then if i take it up to 60, not only does the vibration get worse I get a little metally noise, dosnt quite sound like grinding.
    Got the Service guy out in the car on Friday and he said he could feel it but he's not a vauxhall expert so I dropping it off tomorrow, said he will check over the wheels and tracking stuff and if he can't sort it he'll put it up to Vauxhall in Dundee for a warranty repair.
    Been a brilliant car apart from this vibration and since i have had a vauxhall for years and none of the others done it , its doing me head in.
    Any Chance it could be a loose bit of Fairing or something like that ?
    Jun 2007
    Black Country
    as stupid as it sounds, try your tyre pressures, mine was very vibey until i inflated the tyres, now it feels fine again
    Fife
    Quote Originally Posted by Guyver1 View Post
    As i said m8, I tried them at eco 35 front 38 back and standard 29 front 34 back and no difference
    Regular Member LOCKSTOCK's Avatar
    SUFFOLK
    I get a lot of vibration in my car as well. Mainly at about 40 miles an hour not a wobble on the steering wheel, but a vibration through the car.
    Mine is an automatic and i wondered if this was to blame??
    I have tried lowering my tire pressures but still seems to really lump about on even a smooth road.
    Very strange really don't think it wheel balance though.
    Full Member Big Sig's Avatar
    Vectras are very sensitive to wheel balancing. Probably that on such a new car, however it could be something else too.
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    if it coming through the whole car it might be the rear wheels that need re-balancing and if its through the steering wheel then it the front wheels that will need re-balancing hth m8
    Regular Member s0501291's Avatar
    Warrington
    Default Wheel Wobble
    I had a very bad wheel woble on mine. Definatly the wheel balancing. Its worth getting that checked, doesnt cost much, likely candidate for vibrations
    Glasgow
    My GSI has had this problem since i got it nearly 2 months ago yesterday finnaly got round to get the front 2 wheels balanced and they were HUGELY inbalanced, me and the tyre guy were gobsmacked but they are spot on now and problem is COMPLETLY gone!
    Fife
    Quote Originally Posted by byebyeitsagsi View Post
    So was it like i said not a serious vibratioin but there anyways ? difficult to place.
    Arnold Clark did say they tested the wheels before they gave it to me as its obviously been up a kirb at some stage, as the is a wee nip in the tyre ( still legal and a scratch on the alloy. so this is why I saying whell balancing or tracking. Hopefully !!!
    OOhh i could murder someone lol, just like my smooth ride, I aint no boy racer, even though its an SRi 1.8 VVT, I just a normal driver who like a soft seat.
    Also m8 what tyre pressures you using? your a 1.8 aswell ?
    Jul 2006
    If it's been kerbed hard enough the wheel could be buckled - that would give vibration...
    Wheel wobble due to bad balancing usually only appears at certain speeds, not all the time.
    Any chance you could swap that damaged alloy with a known good one just to test it?
  1. vibration
    By steve19cdti in forum Engine & Drivetrain
    Last Post: 11th April 2011, 07:32
  2. 2.2 sri vibration
    By lordreeson in forum Engine & Drivetrain
    Last Post: 27th October 2010, 19:44
  3. Vibration
    By Si-SRI in forum Vectra C / Signum Car Chat
    Last Post: 12th October 2010, 20:46
  4. vibration
    By rich2507 in forum Engine & Drivetrain
    Last Post: 21st April 2010, 17:12
  5. vibration
    By Eddy R in forum Engine & Drivetrain
    Last Post: 20th August 2007, 19:59
