Thread: help needed
    Regular Member pusky's Avatar
    oxford
    Default help needed
    when driveing along with passeager window down getting a very loud metal sqealing/grinding noise from wheels i think?and when i brake at low speeds i get rubbing/grinding noise.all brake pads seem to have plenty of pad on them,could it be someting sticking
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    Get your wheel bearings checked if you are positive there is plenty of life left on the brake pads. And do not drive too fast or far till you get them checked.
    3.2 v6 Signum and loving it
    Regular Member BigP's Avatar
    Apr 2006
    Heated, Electric Recaro Leather
    I had a similar thing once after driving over some gravel. Turned out a stone got stick between the brake disc and dust shield.
    oxford
    been down to vauxhall today to check out the meatl grinding noise,takes the mantanice manager out for a spin.BREAKS HE SAID.not ****** rocket science,had a quick look at back dices.wheels not removed and said new pads and disics on the back
    as easy as that then...
    for some reason rears wear out quicker than fronts... just a quirk of vectra-c..
  1. Amp help needed
    By minimission83 in forum Electrical & ICE (including SatNav)
    Last Post: 5th March 2012, 22:17
  2. help needed
    By sebadee in forum Engine & Drivetrain
    Last Post: 21st January 2011, 19:57
  3. Help needed!!
    By seannygoat in forum Electrical & ICE (including SatNav)
    Last Post: 26th December 2010, 17:23
  4. Help Needed
    By Andie-100 in forum Engine & Drivetrain
    Last Post: 19th December 2010, 21:51
  5. How To Needed........
    By spennny in forum The 'Off Topic' room
    Last Post: 17th July 2009, 14:17
