Results 1 to 10 of 16
Thread: £4 of unleaded in a diesel.... big problem?
    Jun 2007
    Devon
    Default £4 of unleaded in a diesel.... big problem?
    Obviously just a hypothetical question here chaps....
    How much of a problem would £4 of unleaded be ontop of 1/2 a tank of diesel?
    When considering your answer please make the following hypothetical assumptions
    1. The driver is a moron
    2. The car has been driven 15 miles
    3. The driver is a moron
    4. The driver has little time
    5. The driver has little mechanical knowledge and is likely to break something if the tank needs to be drained etc.
    6. The driver is a moron
    There seems to be conflicting advice on tinternet, either just keep topping it up with diesel and let it work its way through as its such a small amount, or drain the lot, change the filters, drain the lines etc etc and then refill with diesel
    Regular Member Craig1985's Avatar
    harwich essex
    fill the tank right up with diesel, should be ok. i put £10 petrol in works dti. it was fine
    Regular Member poves's Avatar
    lancashire
    Problems arise when you put diesel in a petrol car .
    I sold my 2.2 diesel to a mate and the same day he put £25 unleaded in .
    I drained it but sure there must of been some still in there but it was ok , so I personally would get a fuel treatmant in there , and keep topping up with diesel.
    It might run a bit off key for a few days , but I would chance it , good luck.
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    as to the above to replys m8 just keep it top up and should all be okay
    Jun 2007
    Devon
    Cool I am hoping because its such a small amount it should be ok :/
    I do about 70 miles a day so I will just top it up each evening.
    My only concern with that, is that will the unleaded float and never mix in?
    P.S you guys are legends!
    Regular Member addyboy1982's Avatar
    Northampton
    It's only £4 so not the end of the world, brim the tank every day for the next few days to dilute the petrol and it should be fine.
    A mate of mine who works for the Police did the same thing, they had given him a brand new Astra diesel CID car to go on a course in, he went to the petrol station and brimmed it to the top with unleaded - oops
    it will slowly work its way through with the diesel
    lancashire
    Quote Originally Posted by Adamdavi3s View Post
    It would be the diesel that would go to the top mate , so the petrol should mix.
    Like when you see an oil slick , diesel is heavy oil , more consistency than petrol.
    Don't worry.
    member of the smoke patrol 230bhp+
    it will be ok to fill it right up and keep it full for around 500 miles and you should be fine
    your not the first and i bet not the last to do the same
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    mate of mine always puts £5 petrol with £50 diesel, never had a problem but thats on the old astra dti
  1. 2.2 Diesel starting problem
    By regjames in forum Engine & Drivetrain
    Last Post: 26th April 2013, 16:21
  2. Unleaded or Super unleaded in a new car?
    By John Bishop in forum General Motoring Chat
    Last Post: 10th November 2012, 00:56
  3. Is Unleaded price overtaking Diesel??
    By wickedwillie in forum General Chat
    Last Post: 16th June 2009, 23:36
  4. How To drain a tank when putting unleaded into a diesel
    By bren in forum Engine & Drivetrain
    Last Post: 1st November 2007, 19:30
