Thread: help! Light showing on dashboard-please read.
    Regular Member paulreg54's Avatar
    CHESTERFIELD, DERBYSHIRE
    Default help! Light showing on dashboard-please read.
    hi ive had a car shape light with a spanner in the middle on my dash for about 3days now and before if i turned the engine off and back on it went off but now its on most the time. ive looked in the handbook and it says to take it to the dealer who are not there as bank hol but i need to use the car to go to work! i thought id done with all this when i sold my mk3 vectra! is there any way i can solve the problem myself?
    cheers paul
    Regular Member addyboy1982's Avatar
    Northampton
    Mine threw up a fault a little while ago, there was nothing obvious wrong with the car so I disconnected the battery for 20 mins and when I turned the ignition on after re-connecting the light didn't come on - job done
    ive taken my vec to the garage this morn m.o.t's due next month they want £45 to reset my light! if i undo the batt will i lose any settins like radio code n so on?
    cheers paul
    Regular Member vectragsi3.2's Avatar
    Feb 2007
    cheshire/staffordshire
    dont know about radio code but it justs reset the computer and you will have to reset the electric windows so they go automatically up and down without leaving your finger on the button and thats it unless the radio does need the code to be put back in!! but i would disconnect the battery for a bit then connect it its easy to put things right and will save you £45
    Surrey
    £45 to plug a cable in and clear codes...must be a stealer.
    I thought the radio settings depended on whether it has full CAN bus or not. Anyway mine never lost it's radio settings. Take it to a local garage that can do the MOT who does servicing as well and ask them nicely to reset the light.
    the local garage wants £25 to reset when they do the mot!
    whats a full CAN bus?
    ive bin told you can set the doors to lock when your drivin as well is the right or not?
    cheers paul
    Surrey
    You can do it yourself. There is a how to around.
    Surrey
    May 2006
    scotland
    If you have thumbwheels and button controls on your steering then you have full CANBUS capability. I have full CANBUS on my car and never need radio code after battery disconnection. By disconnecting the battery for a period of time, if the fault is no longer present, you will still see the spanner light until engine fires at which time it will go out (this is a note that a recent fault has occurred). If fault does not re-appear within the next month of normal driving, the spanner light will dissapear altogether. If however, the fault re-appears the spanner will be back. My advice, suck it and see, it may never return (like mines did in Feb this year, never seen it again and that was 6k miles ago)
  1. Headlight adjustment light showing!
    By Lee_gsi in forum Vectra C / Signum Car Chat
    Last Post: 25th January 2011, 22:30
  2. Picture needed of clock dials showing were eml light is please?
    By richiem in forum Vectra C / Signum Car Chat
    Last Post: 24th January 2011, 21:36
  3. oil light showing
    By twaiter in forum Engine & Drivetrain
    Last Post: 11th December 2010, 11:51
  4. help! Light showing on dashboard-please read.
    By paulreg54 in forum Vectra C / Signum Car Chat
    Last Post: 24th August 2008, 13:53
  5. Engine light showing after bumper refit
    By lofty in forum Vectra C / Signum Car Chat
    Last Post: 9th March 2008, 17:56
