Thread: Fitting Sony Head Unit in place of Factory CD30
    Regular Member FACUP76's Avatar
    Feb 2006
    Basingstoke
    Default Fitting Sony Head Unit in place of Factory CD30
    Hello,
    I have a September 2005 Vectra SRI and I'm just in the process of swapping the CD30 Factory unit for a Sony Head Unit. I bought the Facia Plate and Loom adaptor from Vauxhall and went out to fit it this afternoon.
    I have got as far as removing the Factory unit and Cage but following the Vauxhall Guide, there appears to be a page missing where it looks like I have to remove the Cigarette Lighter and attach some wires. Can anybody help on how to get at this without destroying any of the facia. I had a poke around but it seemed a bit flimsy.
    Also does the supplied Vauxhall Adaptor fit straight with the Plug output on the Sony Unit. It looked like some wires (when plugged together) would not match up with each.
    Thanks for any help you can give.
    I'm new to this site, so something like this may have been covered already. Is there a how to somewhere showing the change for the head unit??
    Regular Member The Doc's Avatar
    'Norf Yorks.
    You might need a loom adaptor for the stereo inputs and outputs too mate.
    I don't know about the audio looms/adapters side of things for the C, but this PDF will show you how to remove your cig lighter.
    HTH
    Jan 2006
    Skynet HQ EMEC#5
    I fitted a Sony head unit into my 2003 vec sxi. The harness that came with my facia adapter fits between the car harness and the head unit harness. It converts the big single vehicle plug down to individual pugs for power, speakers, etc.
    I now no longer need the adapter harness due to fitting a CONNECTS2 control box.
    This allows me to use steering wheel controls and puts track info onto vehicle display.
    I believe this only works with the older button type steering wheel controls.
    Feb 2006
    Basingstoke
    Hello,
    Have managed to sort it out now so thanks for your help.
    Regular Member fireblade's Avatar
    Feb 2006
    at home
    The reason the vauxhall guide says to go to cig lighter is to get an ignition source so radio go's off with ignition as the cd30 unit use the can-bus to tell it the ign state and most after market head units cannot read the can-bus signals , some vectras have a phone loom to right behind glove box which has another ign source, not all vectras have this most from germany do most uk don't
    to tell if german or uk open drivers door and look at sticker on b-pillar if it says vauxhall then it is uk if it says opel then it was built in germany mine is german and has loom
  1. sony head unit problems
    By pyper_honda in forum Electrical & ICE (including SatNav)
    Last Post: 11th August 2009, 01:00
  2. Sony CDX GT500 CD/MP3 Head Unit...
    By Dan_BlackSRi in forum General items for sale
    Last Post: 22nd April 2009, 10:02
  3. New Head Unit - Sony bt3600BTU, what do i need?
    By gekornro in forum Electrical & ICE (including SatNav)
    Last Post: 7th November 2008, 20:18
  4. Removal of Factory Fit Head unit
    By akulla in forum Electrical & ICE (including SatNav)
    Last Post: 7th November 2007, 18:36
  5. sony head unit
    By david-bell in forum General items for sale
    Last Post: 17th May 2006, 18:59
plug to change cd30 to a sony
