Thread: Snowy Foamy Stuff
    Regular Member hudz's Avatar
    northern ireland
    Default Snowy Foamy Stuff
    Got sum of this stuff 2day plus the lance for a karcher pressure washer.Can anyone give me sum tips on mix ratio and stand time for foam before i give it a blast 2morrow!
    Cheers in advance!
    Chester
    If it's the Autobryte one it's about an inch of Snowfoam and the top up with warm (not hot) water.
    Dwell time is around five minutes. If the car is really dirty. Snowfoam it twice. The first time rinse off with the lance upwards (The foam will be "blown" into all the nooks and crannies) and the second time rinse downwards as normal.
    You can spray the foam onto the wheels and arches but remember to reduce the pressure when rinsing wheels and bumpers. Try and keep the lance at an angle. Not head on onto the paint when rinsing.
    Also clean the wheels as you would normally before snowfoaming. They are normally have the most dirt on them so if you do them second you'll be blowing crap all over the car when you come to clean them.
    Regular Member shan's Avatar
    I done the wife's Astra today. I used about 1/4 ltr of soap and 1/4 ltr of water in the foam bottle. And away you go. I let the snow soak in for about 10min's then jetted the car from the bottom up to get the all the soap in the nuck's and crany's. Then used the normal bucket and mit method.
    northern ireland
    Thanx guys,gives me a good start 4 2morrow.
    Don't forget the picture's
    Chester
    Quote Originally Posted by shan View Post
  1. Hi from snowy Liverpool
    By Fuzzynuts1984 in forum Introduce yourself.
    Last Post: 21st January 2013, 22:09
  2. Hello from very snowy Riga :)
    By ReynardKryger in forum Introduce yourself.
    Last Post: 8th December 2012, 07:28
  3. A Hi from snowy Scotland!
    By blacksapphire in forum Introduce yourself.
    Last Post: 4th February 2012, 12:48
  4. Snowy Wigan
    By SteveH in forum General Chat
    Last Post: 24th December 2009, 17:57
  5. A foamy day at the beach
    By AJA in forum General Chat
    Last Post: 29th August 2007, 13:13
