Thread: Steel wheels tyre size question
    Stevenage, Hertfordshire
    Default Steel wheels tyre size question
    Guys
    I need your advise
    (apologies if this question has already been asked)
    I have a facelifted 1.8 (Non VVT) Vecci (registered Feb 06 on a 55 plate)
    It is the 'life' model and currently is fitted with 16" steel wheels and has Pirrelli P7 tyres in 205/55/16 H from the factory
    I'm considering changing the tyre size to perhaps 215/55/16 V to get just a little more cornering bite and stability.
    But
    I'm unsure if there are any width differences between the steel and alloy wheels and any other problems I may encounter.
    Hopefully you'll provide your usual excellent and informative advise.
    Regular Member addyboy1982's Avatar
    Northampton
    I had 215/55/16s on my DTI when it has the standard steelies on it so can't see why you shouldn't be able to upgrade to that size from your 205s.
    Jul 2006
    Yep, both 205/55 and 215/55 are listed in the handbook, either will be fine
    Regular Member freespray's Avatar
    derbyshire
    Quote Originally Posted by undecided901 View Post
    Guys
    I need your advise
    But
    Hi I know from previous mods on cars and wheels is that a wheel will take 3 (yep 3) different sizes.
    I'll explain
    1. the standard size, usually the one it comesfrom the factory
    2. under size, usually 1 size smaller more to save on cost
    3. over size, 1 size bigger, should give the car more grip but usually more expensive
    hope this helps a little
    I would have thought the better option would be to buy an alloy and tyre package sometimes works out as cheap and an easy upgrade/mod.
    Oct 2006
    Waterloo, Liverpool
    10 Post(s)
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    Your car would have been fitted with 215/55/16 W at the factory. 'V' rated tyres should be OK for that engine.
    16" Steel and alloys factory-fitted with the above size tyres as standard.
    Regular Member 67688c's Avatar
    Apr 2008
    In UK
    Quote Originally Posted by john_k_sri View Post
    Yes I thought thought the standard size is 215/55/16. I still have the structured steel wheels and thats the size of mine.
    Regular Member John C S's Avatar
    May 2007
    Gangsta crossover on the drive? Check
    I've got 215/55/16 W on mine as standard. Whether or not you'll get the cornering bite you need, I can't answer not being able to compare.
    Also, for example, if you overcook it and go in too fast around a roundabout, the Cornering Braking Control System (CBC) cuts in and tucks the front end back in and prevents understeer developing.
    I just think with a 1.8, you'll not notice too much of a difference between the two sizes.
    The 205's are generally less expensive too, as a lot more car manufacturers use 205's than 215's. ( not my opinion, but the tyre fitter I use)!!!!
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    i also had 215/55/16s on mine when i got it
    member of the smoke patrol 230bhp+
    225/55/16 is this the best way to go on 16's
    thats what i use on my spare wheels and there fine
    Jul 2006
    Not an approved size though...
  1. Tyre size on alloys vs steel wheels
    By fastbatard in forum Suspension, Wheels & Brakes
    Last Post: 3rd December 2010, 00:59
  2. 17" Wheels and tyre size 215 45 17
    By JRBVectra in forum Styling
    Last Post: 9th November 2009, 22:32
  3. Tyre size question?
    By Spider101 in forum Vectra C / Signum Car Chat
    Last Post: 24th March 2009, 16:39
  4. Tyre size Question
    By caledonia in forum Vectra C / Signum Car Chat
    Last Post: 17th September 2008, 12:41
  5. Tyre size change question...
    By abbeytec in forum Vectra C / Signum Car Chat
    Last Post: 2nd September 2008, 23:00
