Thread: 10W/40 Oil
    Regular Member 3.2_V6_VXR's Avatar
    S.Wales, Nr Swansea
    Default 10W/40 Oil
    Is it ok to use 10W/40 Oil in my 3.2 V6 now, if im going to have it serviced by VX in 2months where they will put the 5W30 in.
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    Quote Originally Posted by 3.2_V6_VXR View Post
    it might be a bit to think as i would stick with the 5w/30 as recommended
    S.Wales, Nr Swansea
    i know but if its safe to use for a few months il try the 10w/40 as its slightly thicker and hopefully cure the tapping noise of the hydraulic follower after i used the engine flush
    i surpose it wouldnt hurt for a few months
    S.Wales, Nr Swansea
    Quote Originally Posted by glynn View Post
    I just looked in my service book and it says 10w40 can be used
    give it a try m8 and hope it works
    S.Wales, Nr Swansea
    its only until the service where il get VX to strip the top end down just to make sure
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    For my 3.2, Opie Oils (dealer on here), recommended Fuchs Titan Supersyn 5-40 http://www.opieoils.co.uk/p-984-fuch...ngine-oil.aspx not the Fuchs Titan Supersyn Ecoflex 5-30 http://www.opieoils.co.uk/p-992-fuch...l-engines.aspx
    london
    confused what about 5w40 in 2.2 vec?
    hello , Is it also safe to use 5w 40 fully synthetic in vectra 2.2 2003, instead of 5w 30. only just realised after putting it in my engine? thanks a lot.........
    Regular Member addyboy1982's Avatar
    Northampton
    Quote Originally Posted by pinnacare View Post
    Can't see it being a problem, I used to use 5w40 in my old 1.8 with no problems
10 40 oil in vectra 3.2 v6
vectra c 2.2 10w40 oil
