Thread: lights
    May 2008
    n.ireland
    Default lights
    I've got a 2007 150cdti. The dipped beam lights are useless and I can see F all. I am going to change bulbs does anyone have any recomedations?
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Have you tried the headlight aim mod?
    Essentially, if you adjust them slightly upwards, they are better.
    Simply put, drive up to about 6 - 10 feet from a wall etc, put the aim selector switch (next to headlight switch) to zero, draw a line on the wall corresponding to the upper edge of the light beam pattern, then switch the headlight aim down by 2 clicks. Then manually adjust the headlight aim adjusting screws on the headlight units, so the beam pattern top re-aligns with the line you drew earlier.
    You will notice a huge difference. Or you can fit new bulbs, BUT if the aim could be improved on too, then it will be a double edged sword.
    Sorry, can't help with other bulbs, as I have never needed to replace one on mine.
    Here, there and every where!
    Do the aim mod and fit some of THESE. I've just fitted them and they are much better than the standard lamps.
    I've changed the main beam for some Ultra blue H1's too. Much better now
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    these are much better than vision+ (atleast i feel so, tried both) http://www.lighting.philips.com/in_e...ghting&lang=en
    May 2008
    n.ireland
    cheers for the advice I'll try the headlight aim mod later. thanks
  1. Brighter Lights for side lights, Vectra SRI150
    By 150_SRI in forum Vectra C / Signum Car Chat
    Last Post: 13th July 2011, 23:50
  2. Replies: 2
    Last Post: 31st March 2010, 13:30
  3. Philips bluevision h7 head lights & side lights brand new
    By davidlewis24 in forum Parts for sale
    Last Post: 19th March 2009, 22:42
  4. Dark lights and Rear Lexus lights finally fitted
    By Leviathan in forum Styling
    Last Post: 29th February 2008, 22:35
