Results 1 to 10 of 15
Thread: 3.2 GSi Tapping Help!
    Regular Member 3.2_V6_VXR's Avatar
    S.Wales, Nr Swansea
    Angry 3.2 GSi Tapping Help!
    Since this morning my car has made a tapping noise from the top of the engine, (its defo not the bottom end) it sounds like a tappet from the middle front bank, would this be hard to change and whats the worst case that could happen if the tappet fails?
    Regular Member pogo's Avatar
    Feb 2006
    Vehicle : Audi
    Trim : A5
    Engine : 2.0 turbo petrol
    weve had the same problem with the wifes astra convertible with 1.8 16v engine and the car came back from dealers today after having been checked over by stealers staff and indeed vauxhall field technician and not one of them has cured the fault,ive been told to drive the car and if it gets worse take it back too them,feekin vauxhall dealers dont you just hate them!
    it sounds like it's just a noisy hydraulic follower.. is it close to needing a service? or has it just been serviced?..
    Normally an engine flush will cure the noisy follower...however if it needs to come out, then they are about £16 each if you can identify the exact one.. or £16 x 24 if you can't.....
    the cams need to come out, but the heads can stay on...worst case is noise and a decrease in performance.. it won't ruin the cams..
    S.Wales, Nr Swansea
    It was serviced 5000 miles ago mark which would have been over a year ago, do you recommend i try some engine flush and fresh oil? how much do you think VX will sting me to have the Hydraulic follower changed? cheers for the help so far mate
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    known the dealers they will charge and arm and a leg
    Full Member Big Sig's Avatar
    Plus do the wrong one or insist all of them are changed
    if it was my car i would do a flush and oil change now...then worry, if it doesn't quiten down...
    labour times would be in the order of 6 hours to strip and change the followers..
    S.Wales, Nr Swansea
    OUCH that much labour lets hope the flush will work tomorrow then, would it be a difficult job for your average DIY'er? ie me
    and they probably would charge about £65 per hour plus vat
    S.Wales, Nr Swansea
    Quote Originally Posted by glynn View Post
    Thats what i was thinking Glynn
  1. tapping sound
    By cutchy in forum Engine & Drivetrain
    Last Post: 22nd December 2011, 21:26
  2. Tapping at top of engine
    By TONY.N.F.F.C.ROSE in forum Engine & Drivetrain
    Last Post: 11th April 2010, 10:45
  3. Tapping noise
    By james tierney in forum Vectra C / Signum Troubleshooting
    Last Post: 7th April 2010, 12:28
  4. tapping
    By big rich69 in forum Vectra C / Signum Car Chat
    Last Post: 20th December 2008, 22:08
  5. Tapping Noise
    By jay146 in forum Vectra C / Signum Car Chat
    Last Post: 24th January 2008, 15:28
