Results 1 to 2 of 2
Thread: cam belt change 1.9cdti (120)
    Regular Member bigsteve's Avatar
    Apr 2008
    Nottingham
    Default cam belt change 1.9cdti (120)
    Hi guys, i've got an '05 vectra 1.9cdti (120) and wondered what would be the sensible mileage to have the cam belt changed at, it's currently got 43k miles and, how much is this likely to cost, any info greatly appreciated cheers.
    Jul 2006
    I think Vauxhall suggest you can get 100,000 miles from a cambelt on the 1.9CDTi... I personally would get it done much, much sooner than that. Like about now
    As it's now out of warranty, no need for genuine Vauxhall parts or Vauxhall dealers to do the work - give your local motor factors a ring and see what they can do, I'm sure someone posted recently they got all the parts for around £150 which is half what the dealers wanted! Then ring a few independent garages a call and see what they charge.
  1. replacing 1.9cdti aux belt
    By stevie16v in forum Engine & Drivetrain
    Last Post: 14th October 2011, 14:55
  2. 72k on 1.9cdti 150...should I get timing belt done?
    By marky2027 in forum Vectra C / Signum Car Chat
    Last Post: 14th March 2011, 15:14
  3. 1.9cdti Cam belt change
    By vainparasite in forum Vectra C / Signum Car Chat
    Last Post: 9th May 2010, 18:47
  4. 1.9cdti (150) timing belt change £210 is this ok?
    By kirkyoke in forum Vectra C / Signum Car Chat
    Last Post: 17th March 2009, 22:36
