Results 1 to 10 of 11
Thread: 314mm Brake Caliper code..?
    Regular Member dv8's Avatar
    Apr 2008
    West Mids
    Vehicle : Veccy C
    Trim : SRI
    Engine : CDTi
    Default 314mm Brake Caliper code..?
    Hi Peeps
    For those who have done the 314mm saab supplied kit upgarde...
    Just wondering, popped into VX to get some bolts and stuff,
    On speaking to VX, they say they caliper casting should have code 971 and 970 one on each to reflect the left and right hand...
    the kit i have has two 971's, albiet the nipple is located differently.
    Are VX correct? or talking BS..
    Will the thread to connect the brake pipes be the same?
    DOT 4 brake fluid?
    cheers lads... was pretty sure before, now getting confused.
    Regular Member BigP's Avatar
    Apr 2006
    Heated, Electric Recaro Leather
    IIRC they are sided, although I don't know anything about markings. I believe when fitted the bleed nipple should be pointing up. HTH
    Winteringham
    just checked mine that I got from LMF they are both 971's with nipples in different positions
    VX are having a 'moment'..
    the calipers just need to be fitted with the bleed nipple upwards ( not like some members ) and the fittings are identical between the calipers...
    DOT4 will be fine...avoid silicone DOT5.1 fluid at all costs...but DOT5 is okay..
    Winteringham
    why avoid 5.1 thaught it would be better to change all fluid for 5.1
    silicone fluid doesn't mix or work well with the ABS pumps and the brake seals....
    It's okay in brand new systems that have the seals to cope with it, but not as a 'drop in' replacement for cars filled with mineral based fluid..
    Apr 2008
    West Mids
    Vehicle : Veccy C
    Trim : SRI
    Engine : CDTi
    thanks GSI... once again came to the rescue...
    I understand the logic of having 2 codes one for left and other for right. but as the bleed nipples are located in oppisite sides of the caliper casting i thought i may be wrong. i even began to doubt myself, Im glad its not just me having the 'one of those days' every now and then!...lol
    Do VX use dot4 from the factory...? i feel it maybe best just to use the same.
    yep, VX fill with DOT4 , so even if you fill with DOT5 unless you do a TOTAL system flush the remaining DOT4 will only give the new DOT5 a rating of DOT4 anyway... ( if you follow)..
    So, fill it with DOT4 and pressure bleed ( or vacumn bleed it)
    Apr 2008
    West Mids
    Vehicle : Veccy C
    Trim : SRI
    Engine : CDTi
    Quote Originally Posted by carteg View Post
    thanks mate!... feel better know!
    Regular Member simon1's Avatar
    Oct 2007
    Leicester
    Vehicle : Insignia elite tourer vxline biturbo
    Trim : Elite vxline
    Engine : 2.0 biturbo
    Mileage : 80000
    the kit i got from the milton saab place did have a 970 and 971 caliper.. take the pads out and have a look at the arrows on them you may find that one set wont face forward as the pads supplies are directional ones we found this out when fiting my mates set who had 2 970 ones ., even though they fitted with both nipples to the top .one set of pads had arrows the wrong way
  1. 314mm caliper clips
    By Caveman_nige in forum Suspension, Wheels & Brakes
    Last Post: 21st May 2015, 17:45
  2. Brake Caliper Painting/Caliper Decal's??
    By BigMan in forum Vectra C / Signum Car Chat
    Last Post: 12th August 2007, 21:14
