Likes Likes:  1
Thread: Car / engine shaking
    Regular Member old cruiser's Avatar
    slough
    Default Car / engine shaking
    Strange issue going on here guys that I hope you can help me with, have some ideas but not sure if i'm barking up the wrong tree; When coming off the throttle when only doing around the 40mph mark ,I'm finding that the car has this slight shaking going on (not felt through steering ,more as if the engine maybe shaking) as If i'm shaking my backside in the seat as it were!! if that makes any sense, seems more noticeable in 4th gear (although can be detected in any gear really) and when the revs are coming down to around the 2,000 rpm area, I'm wondering if it's possibly the throttle body and breathers need a clean out? or maybe the EGR (not sure when this comes into play) also on idle I can feel it missing very slightly although when the air-con is on the idle seems to be ok ! what do you think? it's a Z22SE engine by the way.
    Cheers Pete
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    It could be you DMF.
    slough
    Thanks mate, but mines a petrol engine as I didn't think they had DMF?
    Cheers Pete
    Vehicle : SRi
    Mileage : 137000
    Yes mate, we have the DMF also.
    slough
    oh S**T !!
    Vehicle : SRi
    Mileage : 137000
    Quote Originally Posted by old cruiser View Post
    oh S**T !!
    Vid is looking into details to see it a Vec B 2.2 F23 box none DMF set up can be put onto the Vec C. I dont know how far he got though or what the sticking point is.
    Regular Member ade0303's Avatar
    Cheers Pete
    mine does this and its an 07 plate......should it be going in?
    Vehicle : SRi
    Mileage : 137000
    Quote Originally Posted by ade0303 View Post
    Yours is a 1.8vvt and it has a known issue with the DMF. So if it is your flywheel then its covered.
    Regular Member tga's Avatar
    Budapest
    Vehicle : Vectra C GTS
    Engine : Z22SE
    Mileage : 287000 km
    Hi everyone, unfortunately I have a same (Z22SE) engine related shaking problem. It showed up after 275K km (170K mi), so we replaced DMF, whole clutch kit and gearbox (left) side engine mount (because of leaking), but the shaking in 4th-5th gear between 70-80 km/h (40-50 mi/h) speed remaind from right side of the car. We checked all the other engine mounts as well, but those seems in good condition. Ive no more idea, what can cause it. The wheel is out of game, because the shaking presents with winter and summer tyres as well. Every little idea would be appreciated.
    Budapest
    Engine : Z22SE
    Mileage : 287000 km
    Problem solved. If someone is interested, the inner driveshaft CV joint were wobbling on both side (surprisingly the outers are intact). So my mechanic replaced them, now the engine is running smoothly, and no shaking at all.
  11. Likes HarrysDad liked this post
  1. Engine Shaking the whole car
    By inchy1981 in forum Engine & Drivetrain
    Last Post: 17th December 2012, 14:34
  2. Odd shaking - Am I going mad
    By Tim525 in forum Engine & Drivetrain
    Last Post: 5th February 2011, 17:31
  3. shaking whole car
    By alijlacy in forum Vectra C / Signum Troubleshooting
    Last Post: 15th December 2010, 17:20
  4. Engine Shaking 2.2 Direct
    By Sean-2.2Direct in forum Engine & Drivetrain
    Last Post: 28th May 2009, 16:59
  5. Shaking 3.2?
    By jamesr in forum Engine & Drivetrain
    Last Post: 28th September 2008, 08:03
