Thread: traction control
    Regular Member fireblade's Avatar
    Feb 2006
    at home
    Default traction control
    anyone got a 2005 on cdti150 sri and fitted traction control button?
    AJA has a 2004 all he did was fit the switch and now he can turn traction off but his is the older one without interior can-bus but on my 2005 with the interior can-bus system fitting the switch does nothing
    I tried the vauxhall dealer but they are neither use nor ornament after years of good service from honda dealers ,vauxhall dealers are dissapointing
    Has anyone enabled the system so the switch will work?
    Wink
    Call me stupid, but surely on your 05 vec cdti all they would need to do would "Tech-2" it..
    maybe im wrong, i know they are cuttin down on the "extras" so that they can charge people more for them to be put onto your vehicle..
    Sorry i can't help with any more info.
    Feb 2006
    at home
    I asked them to plug the tech2 into my car while i watched but they would not saying i would have to wait 2 hours before theycan look at it
    Anyway they said they had plugged the tech2 in and the traction button should work , they don't know why it dosn't and they will need the car for 2 days to find out why
    They don't seem to be that clued up at my local dealers
    South Central England
    12 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Default I did the same mate
    Had better service than you though, they spent half an hour with the Tech two and looking at the system but didn't get it to work. Didn't charge me for that either.
    I rang Vauxhall customer care and they were quite happy to tell me the didn't know anything; whether it would work if I just put it in; whether it could be reprogramed; whether their IQ was based on the number of windows they could open on their desktop in the call centre...
    So I just left it in cos it looks nice...ish. Still lights up but just doesn't do anything.
    Mileage : 000
    There are many threads about the traction control... But to sum it up it seems that it works on some car,s but not on others, as yet it seems to be the luck of the draw.....
    Regular Member Meriva OPC's Avatar
    Jan 2006
    Just Chilling
    The question I have is, how can you tell when it is off. The reason I ask is, I've had my car for 3 weeks and have thrown it about on private ground to find that the car wallowed a bit (comparing this to an MG ZT with sports suspension) and the little green triangle did not flash at all. This makes me think that mine may already be off or I'm a wimp and not pushing it hard enough
    Mileage : 000
    Trophyblue.If the light on the dashboard is on.. even momenteliry then the wheels are spinning, so if the light is on all the time "ie" when you press the "tc" switch then the "tc" is dissabled. mine is a 3.2 it takes quite a bit to make the light come on in the dry , but in the wet it is not too difficult.Sorry to say it looks like you are a whimp, when the road is either wet or damp take off like your ar55e is on fire, that should make the light come on, I dare say Duncan will be able to say more how a 20t goes as he has one amonst many other members.
    Ps I take it you have the "TC" switch on your car...
    Feb 2006
    at home
    trophyblue on mine as soon as i get wheel spin the light starts flashing on the dash inbetween speedo and tacho at the bottom you know its working cause it cuts your power to nothing , if i go round a roundabout wet or dry and give it full throttle you feel the power cutting in and out
    A few of my work mates have the same car as me sri 1.9cdti 150 and the 2004 models seem to allow the switch to work but the later 2005 do not(they swapped on a 54 plate to interior can bus, you can tell because the chrome trim below windows also dissapeared
    wondered if this can-bus diagnostic tool would work
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...e=STRK:MEWA:IT
    12 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    The TC light on mine is orange and looks like a car on wavie skis. No hard to get it on either, just put my foot down at 2000-2500 revs in 1st, 2nd or 3rd.
    The TC button only disables the TC upto 40mph.
  1. my traction control how to
    By jpbroad1970 in forum Vectra C / Signum Car Chat
    Last Post: 25th April 2012, 20:01
  2. traction control
    By ggg1979 in forum Vectra C / Signum Car Chat
    Last Post: 17th December 2009, 18:07
  3. 2.0T Traction Control
    By kryton01 in forum Engine & Drivetrain
    Last Post: 20th October 2009, 17:18
  4. traction control
    By jsnlvxr in forum Electrical & ICE (including SatNav)
    Last Post: 30th January 2009, 21:56
  5. traction control
    By jamesv6 in forum Vectra C / Signum Car Chat
    Last Post: 14th August 2006, 00:13
