Thread: 1.8VVT gearbox issue...
    Regular Member luckyluke's Avatar
    May 2008
    S'port and L'pool
    Default 1.8VVT gearbox issue...
    ... it's not a very important issue, but it's annoying. When I change from neutral to 1st gear it doesn't always engage fully (that's how I feel), so when I'm to change to 2nd gear gearstick sort of kicks me. And then I want to go to 3rd gear, and when I launch it, I can feel it doesn't go smoothly but there is a little resistance and then I can engage 3rd gear. I've noticed it doesn't happen if I change gear very slow and with caution plus I need to push the clatch pedal into the floor. I don't mention engaging reverse gear with car fully stoped, and 8/10 times I can hear grinding...
    I understand how gearbox work, gears engaging, etc. as I know machining processes quite well and I 'live from manufacturing'. But appart from all my knowledge, is it OK? Because I can explain to myself why this heppens, but it doesn't make me happy and I don't know if my gearbox is faulty, I can't change gears or it's typical for VX products
    Any suggestions are welcome
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    The clutch is hydraulic so it might need bleeding, also the gearstick is connected to the box by cables not so they might need adjusting.
    May 2008
    S'port and L'pool
    You recon this should be covered by warranty?
    Regular Member freespray's Avatar
    derbyshire
    Exclamation
    Quote Originally Posted by luckyluke View Post
    Had the same sort of problem with an old cav once it turned out to be the clutch which i had replaced. all was well after
    Vehicle : SRi
    Mileage : 137000
    Should be, but lets face it, you have a problem on a 1 year old car. The 1.8 VVT has a known fault on the duel mass flywheel and VX know about it. Get it booked it, shout the odds if you have to, but they should cover it no matter the problem, unless you are doing 1000's of miles and the clutch has worn as thats not covered. The clutch is easy to bleed though, and it uses the same reservoir as the brakes.
    May 2008
    S'port and L'pool
    Yep, I'm aware of this... But I thought it 'comes' with shaky clutch pedal that I haven't noticed...
    I've got car booked for worn driver's seat lumbard support, a few noises coming from b-pillar cover, brake pedal, etc. Plenty of small jobs, but they seem to refuse some serious works, such as my gearbox issue or rear brakes.
  1. the dreaded af33 gearbox issue !
    By my-first-vectra in forum Engine & Drivetrain
    Last Post: 22nd November 2011, 20:06
  2. Vectra C 1.8 Clutch/Gearbox issue?
    By ukmgdrooling in forum Engine & Drivetrain
    Last Post: 13th May 2011, 22:57
  3. Turbo delay or issue with auto gearbox?
    By DieselHead in forum Vectra C / Signum Car Chat
    Last Post: 21st November 2010, 13:24
  4. CVT Gearbox issue Vectra C
    By Del in forum Vectra C / Signum Troubleshooting
    Last Post: 22nd February 2009, 02:53
  5. Gearbox issue or not??
    By barlos1973 in forum Engine & Drivetrain
    Last Post: 17th December 2008, 01:55
https:www.vectra-c.comforumshowthread.php55883-1-8VVT-gearbox-issue
vectra 1.8 vvt gearbox
vectra vvt 1.8 gearbox
vectra 1.8 vvt slow 1st gear
vectra vvt so slow
vectra 1.8 vvt sri gearbox
