Results 1 to 10 of 15
Thread: 2.2 starting problem
    derby
    Default 2.2 starting problem
    hi, i've got a 2.2 petrol 05 reg vectra which until now has never failed to start .yesterday we did 300 miles without any problems,i came to start it this morning,it fired up first time for about 2 seconds then cut out and would not restart.there is about half a tank of petrol and it turns over no problem,any ideas will be most appreciated,thanks matt.
    Regular Member luckyluke's Avatar
    May 2008
    S'port and L'pool
    Is it 'direct'?
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Quote Originally Posted by luckyluke View Post
    Is it 'direct'?
    It will be on that plate.
    Regular Member benny's Avatar
    Feb 2006
    dudley
    maybe the fuel pump gone awol
    May 2008
    S'port and L'pool
    Quote Originally Posted by benny View Post
    Which one you recon? Good news if it is high pressure one, it's not that expencieve as for a diesel...
    I'd have started form checking the battery, listening if there are any sounds coming from the back of the car (tank pump should be hearable). Maybe it's something pretty simple such as cloged fuel filter...
    11 Post(s)
    Is the car/spanner light flashing?
    Immobiliser related fault if so.
    Vehicle : SRi
    Mileage : 137000
    You have a high pressure pump also up at the engine end, thats the expensive one. There have been a couple of directs on here with that failing.
    derby
    hi again,yes its a direct,i can hear the pump prime when i turn it on,there are no flashing lights on the dash,think i'll go for the filter before i take it in,typical as the warranty has just ran out.
    derby
    hi again,turned out to be the cam chain had slipped on start up,luckily it didnt do any damage to the valves etc,now i've got to try and get money from vauxhall for the the parts.i've been doing a bit of digging about and it looks like this is a fairly common problem so i wont be buying another 2.2.
    Regular Member bill1250's Avatar
    Apr 2008
    Hampshire, England
    you need to invest in the oh so terrific 1.9 cdti exclusiv
  1. starting problem
    By tiimi in forum Vectra C / Signum Troubleshooting
    Last Post: 25th October 2012, 20:32
  2. Starting problem
    By trace in forum Insignia car chat
    Last Post: 7th April 2010, 07:18
  3. Problem...? Vectra SXI...problem with starting after filling with fuel?
  4. Starting problem
    By DerekFB in forum Engine & Drivetrain
    Last Post: 19th August 2008, 19:54
  5. starting problem
    By chunkster in forum Vectra C / Signum Car Chat
    Last Post: 16th March 2008, 13:09
