Thread: Washer Pump
    Default Washer Pump
    Hi, this is my first post. When i try to use the the wash wipe i.e pull the stalk towards me, there is no noise. The pressure has always been low and there is a small leak coming from the bottle when it's full.
    I have looked at the how to page but it seems more likely to be the pum rather than just blocked as there is no noise coming from the pump.
    Any ideas as i am short on time to do it myself.
    Regards
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    Do you mean you can't hear the pump when you're sat in the seat pulling the stalk or when your down by the pump listening to it?
    Both, i use to hear it when sat in the drivers seat and i can't hear it now and i couldn't hear it weh i was out of the car.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Do you get a voltage at the pump when you pull the stalk? If not, then switch / wiring / fuse, if you do then the pump itself looks like it's gone south.
    East Midlands
    Could well be full of gunge in the actual tank or pump its self caused by screen cleaner fluids and the like in which case you wil need to get the thing off to clean it,access via the front passenger side wheel arch liner
  1. Winscreen washer pump
    By Vaux-Man-G in forum Electrical & ICE (including SatNav)
    Last Post: 6th November 2012, 11:51
  2. water washer pump
    By chewy71 in forum Electrical & ICE (including SatNav)
    Last Post: 30th January 2012, 13:39
  3. Washer/pump/dohh!
    By nikroc in forum The 'Off Topic' room
    Last Post: 18th January 2011, 20:03
  4. washer pump
    By cdms811 in forum Vectra C / Signum Car Chat
    Last Post: 6th May 2008, 15:37
  5. screen washer pump
    By simon1 in forum Electrical & ICE (including SatNav)
    Last Post: 24th February 2008, 16:40
