Thread: 05 Plate - 150 CDTi Clutch Noise
    Thatcham, Berkshire
    Default 05 Plate - 150 CDTi Clutch Noise
    Everytime I depress the clutch I hear a rattling noise... any ideas?
    DMF - dual mass flywheel, strong possibility. I think it shows up when the clutch is pressed half way down or so. But before you panic, it could be something very different, although thats what my money is on. Anyone else??
    Do a few searches and have a read. Is your car still covered??
    Thatcham, Berkshire
    Nope out of warranty.
    How much to replace the DMF, and should I get it done ASAP?
    I think they are quite expensive, no idea if it needs doing asap etc. It may not be that, hopefully someone else with another idea will be along shortly
    Apr 2006
    Kingswinford
    Trim : LS
    Engine : 2.0 DTI
    Mileage : 150000
    I had a rattle noise when you pressed the clutch, but only when the clutch was pressed midway. If pressed al the way down, the noise went. Mine was the dreaded DMF, VX wanted £1200 to replaced DMF and clutch. I went to a local clutch centre £550 for both DMF/Clutch, expensive, but better than £1200...If the DMF goes your car wont start as the flywheel wont turn, me thinks.
    2.0 DTI - 2003.
    Thatcham, Berkshire
    Wow!
    How the hell can the clutch go this early - it's only just 3 years old and only done 48k... am beginning to regret buying the thing.
    Apr 2006
    Kingswinford
    Trim : LS
    Engine : 2.0 DTI
    Mileage : 150000
    The clutch didn't go, it was the dreaded DMF that was rattling. Mine was on 65k on an 03 plate, but they seem to change the clutch while changing the DMF. Before I bought the car I did my research with the aid of the fantastic forum and got all the mods done by VX. Then 18 months later, out of warranty, it happened. These DMF are quite notorious for going and to top it all, most if not all new diesels have them, whatever the manufacturer.
    Quote Originally Posted by iRocco View Post
    Wow!
    The clutch will last as long as it does, depending on the person driving it! Unfortunately the DMF is rubbish!
    Regular Member Sundance's Avatar
    Scotland
    Wow!
    if you have a full vx service history then take it to your dealer, you may get help if it is just out of warranty.
    Regular Member willoftoon's Avatar
    FOREST HALL NEWCASTLE ,,,,,OR DECKHAM ,, ON SUNDAYS .. DINNER TIME MAMMY,S
    i know a lad that will do it with vaux parts for 600 but he is in newcastle
  1. Clutch / Gearbox noise / rattle CDTi 150
    By Paul_B in forum Engine & Drivetrain
    Last Post: 1st March 2013, 17:21
  2. vectra cdti noise on clutch
    By hitcho in forum Engine & Drivetrain
    Last Post: 11th July 2011, 00:01
  3. 55 plate SRI 120 CDTI WINING NOISE
    By MistyMorning in forum Engine & Drivetrain
    Last Post: 21st January 2011, 17:22
  4. Dreaded Clutch cdti 150 (56 plate)
    By johnny1983 in forum Engine & Drivetrain
    Last Post: 30th October 2009, 17:12
  5. 1.9 cdti clutch noise?
    By joe2187 in forum Engine & Drivetrain
    Last Post: 10th October 2008, 21:03
