Thread: New Spring -30mm or new shocks and springs -30mm
    Regular Member Craig1985's Avatar
    harwich essex
    Default New Spring -30mm or new shocks and springs -30mm
    hi
    ive now booked in with 888 to have Eibach springs fitted to my exclusice vectra. Cost is £220
    BUT
    For an extra £400 can have Bilstein shocks done aswell?
    total was £670 i think
    Is it worth getting the shocks done aswell? or would springs alone help handling?
    Really id prefere to pay a member for help fitting
    Regular Member sophos9's Avatar
    Norfolk
    If you are having thoughts about changing suspension later then I would say get the whole lot done at once as you will need a geometry setup after which will cost > £50 (unless you know someone with a visual liner!!)
    Springs will help handling however complimented with the right shock, the difference will be pretty cool
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Thats not a bad fitted price on the Eibachs as they cost about £150 on their own.
    I would go for the Eibach sports dampers to match and they should be a bit cheaper than the Bilsteins. Does the fitting cost for the springs/dampers include realignment because if it does its a bargin fitment and one that I would have gone for instead of me and a mate doing it.
    harwich essex
    Quote Originally Posted by merikiito View Post
    That £670 was parts (shocks n springs) and labour, but he said they cant allign? ( i thinks strange?)
  1. PI springs 45mm or 30mm
    By TimTay in forum Handling & Braking
    Last Post: 30th November 2010, 20:50
  2. PI's -30mm springs
    By Chuddy in forum Handling & Braking
    Last Post: 24th May 2010, 22:06
  3. B4's with -30mm springs
    By Lao in forum Handling & Braking
    Last Post: 23rd February 2010, 18:58
  4. 30mm springs???
    By stuee in forum General Chat
    Last Post: 2nd March 2009, 00:12
  5. PI Springs 30mm
    By sy_uk in forum Handling & Braking
    Last Post: 2nd February 2009, 17:11
