Page 1 of 4 123 ... LastLast
Results 1 to 10 of 38
Thread: Blue Led Help Required!
    Regular Member Matt's Avatar
    in a 3 bedroom house
    Default Blue Led Help Required!
    i have problems, i have soldered blue led's on my light box yesterday but only one bulb is working the one in the centre of the 3 in the middle, why is this please .............. HELPPPPPPPPPPPPP
    Regular Member shan's Avatar
    Maybe the one not working is broken. If you have a test/multi meter measure the bulb. It's best to do this before you solder them on just to make sure you are useing good parts.
    only 1 is working ten are not, bought them all from rs.
    Regular Member SignumPhil's Avatar
    Luton, Beds
    Might be a daft question, but have you got them the right way around? LED's have a live and neutral side
    Phil
    How are you measuring them ? They are a diode so i would use Resistance to check them.
    i swapped them the exact same way the old ones came off. so basically i desolded the orange ones and put the blue ones on in there place job done so i thought.
    Like all things electric, it's white man's magic, and swapping them round the other way may work...
    if i had one the wrong way would it cause the whole lot not to work?
    Regular Member Morephun's Avatar
    everywhere
    Vehicle : vec c
    Trim : sri
    Engine : 150 cdti
    Year : 55
    Mileage : 108000
    you could have burned them out with the hot solder these led's dont like heat for too long
    ffs am not happy if thats the case.
  1. 2 siggys - one blue the other petrol blue/green motherwell
    By BYGino in forum Spotted or put a flyer on a Vectra C/Signum or Insignia?
    Last Post: 23rd December 2011, 01:03
  2. metro blue and dodo juice blue velvet results
    By kirky2k4 in forum Detailing and Car Care Discussion
    Last Post: 21st March 2011, 20:15
  3. purple haze or blue velvet on metro blue
    Last Post: 20th March 2011, 20:23
  4. Blue or Blue&White interior? What dya think
    By luke4487 in forum Styling
    Last Post: 19th May 2010, 14:51
  5. Your views required or help required??
    By Colin S in forum Detailing and Car Care Discussion
    Last Post: 18th September 2008, 02:15
https:www.vectra-c.comforumshowthread.php55773-Blue-Led-Help-Required!page4
