Results 1 to 10 of 29
Thread: Brake pad wear warning light
    Regular Member SteveH's Avatar
    Apr 2006
    Wigan
    Default Brake pad wear warning light
    Is it possible to get this Tech 2,ed out of the cars ECU as ive seen a set of pads and discs on ebay , mate works for VX and has his own tech 2
    Just replace the sensor cable when the new brake pads and discs get fitted
    Part is about £10, can be sourced for less than that
    Apr 2006
    Wigan
    what do i do with the cable as i dont think the pads will accomodate it , to be honest i could do with out this feature , thats why im wondering about the tech 2 option
    Regular Member garvey's Avatar
    Co Durham
    just get the new lead and fasten it on the strut out the way
    You could just link it out. Put a cable in the connection so the two connections are joined. Job done Doesn't need tech-2ing
    Apr 2006
    Wigan
    tried soldering the wires together , but it still stays on , im led to believe it uses some kind of resistance ,but i dont understand how that works ????
    The reason I said that is I'm sure someone said they had done that before. It could need to read a known value, bit like the bulb check. For the sake off a tenner, may as well replace them, unless someone knows better?
    Jun 2007
    Black Country
    I might be wrong, but i thought the light comes on to let you know you know your brakes are low, this usually works by the 2 wires in the sensor touching the disc and creating a short which in turn lights up the brake warning light??
    my cable was worn through to nothing, i never replaced it cos the main dealer was shut when i fitted then discs and pads, the light has never been on since
    try seperating the cables, or just unplugging the whole unit
    Regular Member poves's Avatar
    lancashire
    I cut the wire and crossed the connections , light went out.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    I joined the pins in the body side of the connector using a paper clip - that was 12K ago, and the light's not been on since.
  1. Rear brake pad wear - a warning !!
    By blueboy in forum Handling & Braking
    Last Post: 5th October 2009, 19:59
  2. Brake Wear Light
    By peadar in forum Suspension, Wheels & Brakes
    Last Post: 30th November 2008, 17:08
  3. Brake wear warning light
    By spatch in forum Suspension, Wheels & Brakes
    Last Post: 4th September 2008, 19:28
  4. Brake wear warning won't go out...
    By philtr in forum Suspension, Wheels & Brakes
    Last Post: 9th April 2008, 07:28
  5. Low brake pad wear light
    By prm in forum Vectra C / Signum Car Chat
    Last Post: 22nd August 2005, 13:50
