Results 1 to 10 of 13
Thread: Spring Compressors - Any Advice?
    Regular Member sophos9's Avatar
    Norfolk
    Default Spring Compressors - Any Advice?
    I need a set of spring compressors and was wondering if you have any recommendations on what ones to buy?
    I'm after the proper hook ones like this....
    Will 220m length do it?
    Regular Member bish's Avatar
    peterborough cambs :P
    if you was a bit closer you could of borrowed mine
    Norfolk
    thanks for the offer mate!
    How long are they?
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    http://www.screwfix.com/search.do;js...ing+compressor
    Even better if you don't have to pay the £5 P&P and have a store near you.
    Norfolk
    Yup! Will 250mm do it ok?
    Regular Member DeanF's Avatar
    Nov 2007
    Staffordshire
    Quote Originally Posted by sophos9 View Post
    250mm is more than enough, Sometimes with the longer ones, The threaded bolts foul the top of the inner wing whilst your compressing the springs with the shocker fitted, Stopping you achieving a full compression.
    Dean
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    Quote Originally Posted by DeanF View Post
    Dean
    you take out the shock off the hub and undo the 3 bolts under the bonnet first then you use the spring clamps
    Jan 2006
    Hornchurch
    take the strut out first then undo them
    Nov 2007
    Staffordshire
    Quote Originally Posted by glynn View Post
    Ahh. Not always the case !! On some cars the shock extends to far when not under any load & you cannot remove the whole assembly, Even when un-bolted Etc. So you have to clamp 1st
    This has been the case on quite a few vehicles i have done, Although it is down to the design of the Strut Etc, Some have the mounting bracket further up the leg & not at the base ETc.
    Dean
    Norfolk
    Thanks guys, will get the 250mm ordered!
  1. Lowering Spring Advice.
    By tomtaylor15 in forum Handling & Braking
    Last Post: 27th January 2012, 19:04
  2. Spring compressors
    By Middo in forum Suspension, Wheels & Brakes
    Last Post: 2nd September 2009, 21:45
  3. MOT spring advice!
    By Martyn21 in forum Vectra C / Signum Car Chat
    Last Post: 3rd June 2009, 19:30
  4. spring compressors
    By LOCKSTOCK in forum Suspension, Wheels & Brakes
    Last Post: 7th September 2008, 17:05
  5. Spring compressors
    By Jay-C in forum Suspension, Wheels & Brakes
    Last Post: 14th April 2008, 08:24
