Thread: Exhaust or Cam-Chain?
    Northampton, UK
    confused Exhaust or Cam-Chain?
    My car's started to "Rattle" When I pull away and when I'm driving slow in 2nd, maybe 15mph and below... and sometimes when in 3rd doing 20mph or abouts... (All at or around 1500rpm and above) The car was serviced and MOT'd by VX in May, filters, oil etc all changed... So I've done what I can to keep the Cam-Chain oiled up.
    I'm sure my girlfriend had this sort of problem with her car, It turned out to be a loose or broken Exhaust mounting underneath. The Exhaust does wobble a bit at the rear but I havent had the chance to look at the whole underneath yet...
    Is there anyway I can "self" inspect the Cam-Chain and Exhaust? What should I look for?
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Chain would rattle at idle, but zorst could rattle as engine is put under load as the engine rocks.
    Northampton, UK
    Theres no rattle when shes idle, just under load... guess that narrows it down...
    Regular Member v6boy's Avatar
    PRESTON
    Trim : GSI
    Sounds like its this problem
    http://forum.vectra-c.com/showthread.php?t=6242
    rearing its ugly head again. I suffer from this on my GSi, just can't justify parting with the cash to get it cured. Very annoying though; makes a tinny rattling noise when pulling away under load.
    Oct 2006
    Waterloo, Liverpool
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    A worn or stretched chain could rattle if you let the engine labour and try and pick up without changing down. But shouldn't happen at 1500 revs or above in any gear with that engine, but may do so if the chain is worn or stretched I suppose. I have a faint recollection of this very thing which disappeared once the cam chain was replaced and my auxiliary belt was finally replaced with the correct pulley and tensioner.
    The exhaust seems the most plausible of the two possibilities you mentioned.
    The twittering from the auxiliary belt only happens at idle and when the engine is cold and is familiar to some of us 2.0T owners.
    Regular Member ghostrider's Avatar
    On another planet
    Vehicle : 2.0l CDTi Bi-Turbo Insginia Sports Tourer
    Trim : Vx Line Nav Sri
    Engine : 2.0
    Try this
    http://forum.vectra-c.com/showthread.php?t=53152
    Sounds like a similar problem i had
    Tyneside
    The noise from the pulley is very annoying and the easiest way is to warm it up and if it goes away it's the pulley and obviously if it remains it will probably be the exhaust.
    The problem with it being the pulley is it's £120, I've just put up with the noise at it is only a noise and when the belt gets changed it disappears for a while.
  1. 2.8 v6 cam chain
    By 2.8 turbo in forum Engine & Drivetrain
    Last Post: 23rd January 2012, 19:09
  2. Cam Chain 2.2
    By tubby in forum Engine & Drivetrain
    Last Post: 23rd July 2011, 21:39
  3. cam chain and exhaust
    By darlodouth76 in forum Vectra C / Signum Car Chat
    Last Post: 19th April 2010, 18:08
  4. Signum Timing Chain and Full exhaust replacement?!!!! help
    By cjporter in forum Engine & Drivetrain
    Last Post: 12th November 2009, 19:40
  5. Cam chain
    By dankidd in forum Engine & Drivetrain
    Last Post: 16th November 2008, 15:28
