Thread: Passenger door switches
    Regular Member old cruiser's Avatar
    slough
    Default Passenger door switches
    Just a quick question ; there are 2x switches on the passengers door, one with symbol of a car door (believe this is for central locking) and the other is boot opening , however when I press either of these all I get is a beep sound and nothing else happens, any ideas guys?
    Cheers Pete
    Mileage : 000
    When you press the boot opening, it should "unlock" the boot, allowing you to open it, have you tried to open the boot after pressing the boot open button in the door??
    Regular Member m_r_shaw's Avatar
    Sunny Waterloo, just outside Liverpool.....
    AS ABOVE
    The 'beep' is to let you know the boot is now unlocked and you can now open it. you will not hear the 'beep' if the car is moving HTH
    slough
    just tried the switches again and the central locking ones working now!! but the boot one on the passenger side still beeped so pressed the one on the driver's side and that also beeped, however started the car and found the boot unlocked, so one of the switches must have unlocked it!! anyway run out of time fiddling with it now, so will have another play around some other time, just wonder what that beeping sound signifies?
    Cheers Pete
    i think it's just an audible alarm, so you know it is open, i dont think it's anymore than this? although someone will be able to shed a bit of light????
    slough
    Quote Originally Posted by m_r_shaw View Post
    AS ABOVE
    Must have just sent my previous post as you sent yours, so thanks for that at least I now know what the beeping sound means.
    Cheers Pete
    Regular Member mcwharam's Avatar
    Oct 2007
    Leeds
    On my old elite (04) had this - It had auto locking boot. If the car moved off the boot would lock. When stopped you had to press the button to gain access to it. I believe it was to stop undesireables from opening your boot when parked at traffic lights etc
    Martin
  1. Replies: 32
    Last Post: 2nd January 2013, 02:18
  2. Passenger door switches
    By brianjamesreed in forum Electrical & ICE (including SatNav)
    Last Post: 12th April 2012, 19:57
  3. passenger window switches
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 26th May 2009, 15:32
  4. Door Switches
    By tony100la in forum Vectra C / Signum Car Chat
    Last Post: 24th April 2008, 17:13
  5. Set of door switches...ALL doors..
    By armoured farmer in forum Parts for sale
    Last Post: 30th April 2007, 18:39
