Results 1 to 3 of 3
Thread: Gearbox Conversion
    Yorkshire
    Default Gearbox Conversion
    Hi these 2.2 DTi auto gearboxes are like rocking horse phoo second hand!
    So I'm now considering a conversion to a manual.
    Has anybody done a conversion?
    What are my choices of gearbox?
    I've started a list of parts;
    Gearbox (which one to be decided)
    Pedalbox
    Clutch/flywheel assembly
    Driveshafts (not sure if I'll need to swap these until I decide which gearbox)
    Selector mechanism.
    Any more thoughts?
    Regular Member benny's Avatar
    Feb 2006
    dudley
    loads a tech 2 programing ....new drive shafts new gearbox mounts .... interior trim around gear nob.....pedal box is easy to change ..you will need the clutch pipes tho that go across the bulk head....this is a lot of work ..... you may need a new cim as the old one will have the park lock option for the key so this will need removeing ..... keep us posted on how you get on ...oh you will need a new instrument pannel......maybe you need the complete donner car,....
    Yorkshire
    One breaker reconded the drive shafts were the same but I'm open minded about that. I figured the automatic gearbox would nee to be removed from the vehicles sortware but I didn't know to what extent this would be.
    I had not considered the gearbox mountings tho so thanks!
  1. M32 gearbox can`t get gear selector back in gearbox HELP!
    By v33tra in forum Engine & Drivetrain
    Last Post: 18th August 2011, 18:12
  2. 1.9 cdti auto, conversion to man gearbox
    By ricky1 in forum Vectra C / Signum Car Chat
    Last Post: 25th October 2010, 00:02
