Results 1 to 10 of 14
Thread: emission light help!
    Regular Member platty's Avatar
    Jan 2008
    Paisley
    Default emission light help!
    Hi guys, I had to change a bulb today so removed airbox and maf to gain access, my problem is after replacing them I now have the emission light lit on the dash. I tried disconnecting the battery for 10mins to see if it reset. This didn't work and I now have an F where the outside temp used to be displayed. Any help appreciated.
    Surrey
    Bad connection to MAF?
    Jan 2008
    Paisley
    thanks for the reply but as the connection for the maf has a clip that ensures it is connected properly. I don't think this is the problem
    Regular Member ghostrider's Avatar
    On another planet
    Vehicle : 2.0l CDTi Bi-Turbo Insginia Sports Tourer
    Trim : Vx Line Nav Sri
    Engine : 2.0
    leave the battery disconnected for at least 40mins. 10mins isn't enough.
    Mine has done silly things unless disconnected for 40mins.
    Full Member Big Sig's Avatar
    Check the maf connection is clean.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    You didnt turn on the ignition with the MAF disconnected did you? If so it just needs resetting.
    F on the outside temp sensor display means 'FAULT'.. so check the plugin connector for problems.. mind you they are very fragile and sensitive to voltage spike so you may have even blown it.. new one's are around £6+vat from VX..
    Jan 2008
    Paisley
    Hi guys thanks for the replies, I tried leaving the battery disconected for longer as ghostrider suggested, this brought back my temp display. The emission light was still on but has since gone out. The only thing is the emmission light and the car and spanner light stay on untill the engine is started then both go out. Does this mean I have a fault code that needs reset?.
    On another planet
    Engine : 2.0
    Not sure, but i think that suggests all is fine now
    Maida Vale
    For future reference, unless you have really big hands you don't need to remove the airbox to change the dipped beam, main beam or sidelight bulbs. Well, not for pre-facelift anyway.
  1. spanner light reset emission light now on HELP!
    By johnny boy67 in forum Vectra C / Signum Car Chat
    Last Post: 7th December 2009, 12:07
  2. Emission light on.
    By ExclusivDoug in forum Electrical & ICE (including SatNav)
    Last Post: 1st April 2009, 10:36
  3. Another emission light on
    By soulie in forum Engine & Drivetrain
    Last Post: 27th February 2009, 19:38
  4. help with emission light
    By wilsons 1.8sxi in forum Engine & Drivetrain
    Last Post: 10th July 2008, 02:02
  5. emission light
    By pipamish in forum Engine & Drivetrain
    Last Post: 20th March 2008, 08:29
