Thread: Auto Box Problem?
    BROMLEY
    confused Auto Box Problem?
    Hi,
    Just bought the car, Vectra 1.9CDTi Estate Auto, and I've noticed the box is still in 4th gear at 50 mph. When I select the gears manually, it's quite happy to run in 6th gear at this speed. Does the box need adjustment, or is this normal?
    Thanks for any advice.
    Regular Member Darryl2.2DTI's Avatar
    Oct 2007
    Kilmarnock, Ayrshire
    Vehicle : Vauxhall Vectra C
    Trim : LS
    Engine : 2.2 DTI
    Mileage : 106000
    well i have a 5 speed auto in my 2.2DTi and when its in D it does rev higher through the gears. it wnt go into 5th until ur at 40mph. if u put in into manual the it will cruise at 30 in 5th with no problems. think its jst the way the ratios have been set. not 100% sure though. see what the others say.
    BROMLEY
    Thanks for that. Seems to defeat the object if you have to switch to manual to get a higher gear!
    Yorkshire
    A few things to condsider the gearbox will have learned the driving style of the previous owner (assuming you've bought it used). Also the car may be doing more mpg in 4th than 6th depending on the torque being produced by the engine at that speed.
    6th gear at 40MPH is far too higher gear....
    our old 150 auto didn't select 6th til 60mph ( when it could lock up the torque converter)..
    The car is behaving 100% properly and no fault is present....
    May 2008
    Burnham
    Hi
    I've got a CDTi 150 with the 6 speed auto box and initially had much the same concerns as you. Must admit that for the first day or so I didn't even realise that it was a 6 speed box (doooh!). When it went into service I reported the fact that it seemed to hang in the gears. When I collected it, the 'technician' advised me that 6th gear would only be selected when the car was doing 60-70mph.
    cheers
    Malc
  1. Auto box. 4th to 5th problem.
    By RhayaderSax in forum Engine & Drivetrain
    Last Post: 11th April 2011, 12:00
  2. problem with my 3.0 v6 dti auto
    By carl3.0dti in forum Vectra C / Signum Car Chat
    Last Post: 18th April 2010, 10:35
  3. 3.2 Auto Box Problem.. I think!!... Help!
    By VinnyPeewee in forum Engine & Drivetrain
    Last Post: 29th May 2009, 14:18
  4. auto box problem
    By malcolm in forum Vectra C / Signum Car Chat
    Last Post: 16th December 2008, 20:15
  5. Another Auto box problem...
    By john_lickman in forum Engine & Drivetrain
    Last Post: 11th August 2008, 19:29
torwue converter lock up on vectra c 3.2 v6
vectra c auto box problem
