Results 1 to 10 of 16
Thread: CD 70 NAVI cd not ejecting
    Lancs
    Default CD 70 NAVI cd not ejecting
    Hi Guy's, you wonderful lot out there,
    now the grovelling is done, I have a CD 70 NAVI in my car, with the CD stuck inside. When the eject button is pressed, it sounds as though it is attempting to eject, but doesn't. Does this have a manual eject mechanism anywhere, or can it be released by removing the unit.
    Thanks in advance for any info or help
    Regards
    Neil
    Jan 2006
    Hornchurch
    give it a Hit just a light tap
    May 2006
    scotland
    I had this and I drove the car with the heater on full heat for about 20 mins to get the interior roasting then it ejected. Thermal expansion of different parts. Justa suggestion
    Lancs
    Just tried that (tapping it), but did not work on this problem, thanks anyway for that tip
    Regular Member sig63's Avatar
    Belgium
    Vehicle : Opel Insignia
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    try gently inserting another disc while pushing on the eject button
    Before you do this, make sure you have the passcard or know the code number
    Usual solution is to remove the fuse, wait 10 minutes
    Reinsert fuse
    The CD should eject
    If not, then the unit will have to be removed
    May 2006
    scotland
    Heat the front of it up gently with a hairdryer. Not to hot but its may just do the trick
    Regular Member LJ sxi-nav's Avatar
    Winchester
    Quote Originally Posted by sig63 View Post
    What sig63 said - I had an audio CD stuck in my cd70. Unit behaved like there was a CD inserted (it would play) but didn't KNOW it was inserted! Pushing another CD in (use and old CDR and do it carefully LOL) fooled the mechanism that a CD was now in and it ejected the one that was stuck.
    Other people with different units have suggested putting 2 cd's in the slot and trying to sandwich the stuck cd to then pull it out - i couldn't get this method to work on CD70 though.
    Lancs
    My appologies for not getting back earlier, but I have eventually tried a few more tips, but with no success. But have since looked inside the unit though the slot with a torch. And, could not see any signs of a CD. I have also removed the head unit, and removed the CD unit from this. Inside was found a couple of coins, and a guide wheel was also moving around freely. I have put it back together, and tried again, but it appears the debris in there has done its damage, as one of the cogs for ejecting has worn its teeth away.
    Does anyone know where to get hold of a replacement cd unit, or if these cogs are replaceable (maybe at a cd repair place).
    The unit is a CDM M6 4.7/84 SO 736 9307 005 60436
    Thanks again for all the tips recieved earlier
    Neil
    what you need to do is not 'just buy one' on ebay... the unit needs 'un pairing' from the donor car before it can be 'paired' to yours...
    i think it'll either be a case of buying a broken unit to rob for parts, or the expensive route of using VX's own repairers..
  1. CD Player Error (not playing or ejecting)
    By SW-ZC in forum Electrical & ICE (including SatNav)
    Last Post: 9th May 2012, 10:35
  2. Signum in dash autochanger not ejecting?
    By pgilc1 in forum Electrical & ICE (including SatNav)
    Last Post: 8th November 2009, 20:22
  3. CD 70 Navi
    By simsr4 in forum Electrical & ICE (including SatNav)
    Last Post: 5th January 2009, 22:55
  4. NCDC 2013 keeps ejecting the Nav CD
    By David_SRi_2.2DTi in forum Electrical & ICE (including SatNav)
    Last Post: 5th August 2007, 20:06
