Results 1 to 10 of 21
Thread: Caliper problem
    May 2007
    liverpool
    Default Caliper problem
    Hiya, I got a problem with my rear caliper, I think it been sticking cause i had a grinding noise from my breaks and when i looked 1 of my pads had totaly worn to nothing so iam in the middle of changing my pads but ive noticed the the rubber boot has split on the caliper, can i get another or will i have to buy a new caliper? Also what type of grease would i use. Thanks everyone.
    Jul 2006
    Mexico
    Grease? you mean for the break pads right?
    If yes..what you need is copper grease
    the caliper boots aren't avaliable seperately...and if the boot is split there's a change of water ingress into the caliper which can lead to the piston rusting..
    the best cure will be an exchange rear caliper
    May 2007
    liverpool
    Thanks for that info, how much £ are the calipers?
    last one i got was £60+V but thats with discounts...
    best ask at VX to get an accurate price..
    Regular Member phil67's Avatar
    Nottinghamshire
    Vehicle : Vauxhall
    Trim : Exclusive
    Engine : 1.8
    What car are you running dawn, im in the middle of doing the 292 rear upgrade so my old calipers will prob be available, if you are still stuck
    May 2007
    liverpool
    Quote Originally Posted by phil67 View Post
    Hi phil Iam running a 3.2 gsi on a 03, and if they would fit mine that would be great. Let me know when you can. Thanks
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Quote Originally Posted by dawn brown View Post
    You would be downgrading your rears if you fit them. You already have the 292's.
    Nottinghamshire
    Vehicle : Vauxhall
    Trim : Exclusive
    Engine : 1.8
    May 2007
    liverpool
    Ok Thanks anyway Phil it was very thoughtful of you.
  1. New caliper now handbrake problem
    By roverjay in forum Suspension, Wheels & Brakes
    Last Post: 27th January 2013, 19:17
  2. Rear brake caliper problem
    By siadwel in forum Suspension, Wheels & Brakes
    Last Post: 19th July 2012, 16:37
  3. will i need new caliper
    By sebadee in forum Suspension, Wheels & Brakes
    Last Post: 9th March 2011, 02:12
  4. can any1 help caliper problem
    By callum in forum Vectra C / Signum Car Chat
    Last Post: 6th September 2010, 19:10
  5. Brake Caliper Painting/Caliper Decal's??
    By BigMan in forum Vectra C / Signum Car Chat
    Last Post: 12th August 2007, 21:14
