Results 1 to 10 of 13
Thread: Claying
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    Default Claying
    Ok this may seem stupid but ive got some megs clay ready to use before trax (Im saving it) But what i want to know is how do you use it as ive never used it before. is it a case of spray on the lube and rub (Ooh err!) or is there more to it that that?
    Surrey
    Make sure the car is clean. Break it in two, flattern it out spray loads on car. I even spray the clay. Rub backwards and forwards until no resistance. Check clay and re-mould when dirty.
    Jul 2006
    Northampton
    Trim : Sri
    cheers mate! i dont want to mess it up and waste the clay and make the car look ****. from this do i just wash off the residue left over? Soap or water?
    Surrey
    So people don't some do but I would re-wash the car to get rid of the residue.
    Sunny Dartmoor
    Good luck with the claying Dan,you'll will be amazed at the results.......
    Don't forget pic's when done,you should know it by now.....
    Jul 2006
    Northampton
    Trim : Sri
    Thanks lol i know the rules. I will be doing this on the saturday before trax so if your going, you can see the results
    Sunny Dartmoor
    Not going to trax,sad to say,so will be happy with pic's m8.....
    Jul 2006
    Northampton
    Trim : Sri
    Quote Originally Posted by glenboy View Post
    disappointing glen. never mind, ill get some pics up for you
    Regular Member Little John's Avatar
    North West
    Just one thing don't spray to big an area, spray maybe 12" square them clay that bit then move on, if you try to do a larger area you will find the lube dries out when its warm and you may mark the surface.
    When wipeing the clay use just enough pressure to keep the clay on the surface no need to scrub at it, the clay will pick up the contamination as it passes.
    If you find the clay sticks then apply more lube.
    If you drop the clay then bin it or save it for your wheels never use clay on paint that has been on the floor.
    Jul 2006
    Northampton
    Trim : Sri
    Quote Originally Posted by Little John View Post
    Cheers John, ill bear that in mind
  1. New to claying
    By johnny1983 in forum Detailing and Car Care Discussion
    Last Post: 25th March 2011, 13:45
  2. Claying New Car...
    By spoons in forum Detailing and Car Care Discussion
    Last Post: 25th November 2009, 21:26
  3. claying
    By Mads in forum Detailing and Car Care Discussion
    Last Post: 27th August 2008, 23:04
  4. Claying
    By Robbie69 in forum Detailing and Car Care Discussion
    Last Post: 9th August 2008, 18:15
  5. Claying
    By KC in forum Vectra C / Signum Car Chat
    Last Post: 30th July 2008, 16:35
