Thread: CDTI 150 - Total loss of power
    Bristol
    Vehicle : CDTI 150
    Unhappy CDTI 150 - Total loss of power
    Took my 05/05 CDTI to the shops, would have been quicker bringing one of the trolleys back.
    Noticed lack of turbo 'whistle' when trying to accelerate.
    Car almost 2 weeks out of warranty with 59K on the clock.
    Booked it in with VX they found a Vac pipe to the turbo split. Total cost £133.09 so not so bad.
    Pipe cost £17.00 plus VAT.
    Perhaps a fault that may become more prevelant as this model gets older, I will post the part number of the pipe tomorrow.
    Full Member Big Sig's Avatar
    If it was only 2 weeks out of warranty I would still have expected them to help out if not do it for free! It may also be worth looking at the threads on here about "swirl valves".
    Bristol
    Vehicle : CDTI 150
    Hi, Big Sig.
    Had the swirl valves (inlet manifold) replaced a little while back.
    Reason I went back to Vx was I had the turbo replaced under warranty about 10 months ago. Also had the EGR replaced about 1 month ago as a warranty job. I have sent a letter to Vx asking for a contribution to this repair, I will post their response.
    Pipe replaced was Pt No 90543673 Hose 5.3 I-D Cost £17.45 plus VAT.
    They also carrie dout the handbrake recall work.
    Regular Member GoldenWonder's Avatar
    Durham
    Just to hijack this thread slightly...
    My 54 120 had a turbo replaced at 54k under warranty. This seems to be fairly common.
    Did Vx modify the turbo design at all, or is it basically the same turbo? That means I can expect it to fail again at around the 100k mark!
  1. 150 CDTi power loss
    By rockafella8587 in forum Engine & Drivetrain
    Last Post: 15th December 2011, 12:48
  2. 150CDTI - Intermittent total power loss
    By birdii in forum Engine & Drivetrain
    Last Post: 18th April 2011, 22:16
  3. Power Loss on 3.0 V6 CDTI
    By V6Andy in forum Engine & Drivetrain
    Last Post: 1st March 2010, 23:59
  4. loss of power 150 cdti
    By SRI-150 in forum Engine & Drivetrain
    Last Post: 17th May 2008, 14:24
  5. loss of power 1.9 CDTi
    By ALD in forum Engine & Drivetrain
    Last Post: 5th January 2007, 16:25
