Results 1 to 10 of 15
Thread: Anodised metal
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Default Anodised metal
    How would I remove the anodised coating? Heat or just plane old elbow grease.
    Elbow grease, its a bonded/chemical coating, not like painted on.
    East Midlands
    I used to work in this industry many moons ago(anodising and metal plating) and the only way it could be completely removed was a good old dip in hydrocholric acid if you've got any lying about anywhere.
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Cheers, thought as much. Got myself a bargain on ebay but its in nasty red and I want to get it back to metal and polish it up.
    try taking it to an anodisers and asking them if they will strip it... it never removes 100% of the anodising as it etches itself into the metals, surface not just sits on top..then it's out with elbow grease as the surface will still be relatively hard..
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Grinder?
    Nr Cardiff
    Wire wool?
    wire wool won't touch anodising and a grinder may be a bit severe....
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Decided to spray it up. Its not smooth, its looks like it has been milled in a lathe so has loads of ridged all the way round. Cheers for the advice guys.
    put an etch primer on it first.....
  1. Sounds like metal-to-metal from the rear.
    By Vaux-Man-G in forum Suspension, Wheels & Brakes
    Last Post: 2nd April 2014, 12:01
  2. Vectra-B brakes sound like metal to metal
    Last Post: 4th December 2011, 14:42
  3. metal on metal noise
    By neill in forum Engine & Drivetrain
    Last Post: 1st February 2011, 18:33
  4. metal on metal maybe?
    By twaiter in forum Suspension, Wheels & Brakes
    Last Post: 17th November 2010, 17:57
  5. Anodised Bolts
    By Hyperhart in forum Vectra C / Signum Car Chat
    Last Post: 31st May 2010, 22:51
