Thread: vxr steering wheel
    Regular Member pipamish's Avatar
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    Default vxr steering wheel
    hi will a vectra vxr steering wheel fit a 53 plate vectra
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    If you have rollers and not buttons on your wheel then it might. But i'm sure the airbag connections are different so no if i'm right.
    i'd have to say no to that.. the VXR wheel is for full canbus cars...unless your pushbutton switch panels will fit onto the VXR wheel, and you have the identical airbag connectors it's gonna be far from straight forward...
    I beleive chris gettings looked into this type of conversion.. he got quotes of £1800 on the wiring looms alone to make it work
    Regular Member pricey's Avatar
    Dewsbury, West Yorkshire
    I very much doubt the airbag connections will be the same and even if they are then you would need the facelift airbag aswell.
    EDIT - Or what Mark said.
    Regular Member 3.2_V6_VXR's Avatar
    S.Wales, Nr Swansea
    ive fitted a facelift steering wheel to a pre-facelift, you can fit one mate but you will lose the steering control fuctions as your car is half canbus and the facelift is full canbus, but you will have to get an airbag from an early Astra H because they used the single yellow airbag connector which your pre-facelift uses as the vectra facelift airbags are twin connectors
    But if you CAN do it, then it's definitely worth it...
    [Ex]Admin Duncan's Avatar
    Quote Originally Posted by 3.2_V6_VXR View Post
    ...but you will have to get an airbag from an early Astra H because they used the single yellow airbag connector which your pre-facelift uses as the vectra facelift airbags are twin connectors
    His may also be twin airbag connectors as they were fitted on the Vectra from MY 2003.5, not just to the facelift. Being a 53 it would be very close to that breakpoint.
    If he does have the twin airbag connectors then the wheel may fit, but as said he'd need the facelift airbag to fit the wheel and he'd lose the wheel controls as his will definitely be the six button half-CAN and not the Full-CAN scroll wheels.
    S.Wales, Nr Swansea
    i didnt know that D, i thought they changed on MY 2004, learn something everyday on this site
  1. For Sale: Sri facelift steering wheel c/w steering wheel controls
    By andy.l in forum Parts for sale
    Last Post: 3rd February 2013, 16:08
  2. Steering wheel light & loss of power steering
    By the_wave_rider in forum Vectra C / Signum Car Chat
    Last Post: 3rd August 2012, 14:09
  3. Steering wheel warning light , no power steering!
    By Domchapp in forum Vectra C / Signum Car Chat
    Last Post: 23rd July 2012, 22:11
  4. Replies: 6
    Last Post: 13th March 2011, 10:47
where is power steering located in vxr vectra 2005
