Results 1 to 10 of 13
Thread: Heater Fan Blower. Vectra C
    Jun 2007
    Edinburgh
    Default Heater Fan Blower. Vectra C
    Just had a problem on my way home. The fan blower came on by itself and wouldnt switch off when I killed the ignition. I had to pull the fuse. I do have an airbag light on which was caused probably by a car park attendant moving the seat (common problem I believe) when I went on holiday. Could this affect the blower through the ECU? Anybody experienced this before.
    Nicking Ya Dinner.
    Regulator, behind the glovebox, looks like a black box with a heatsink on it.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Not heard of airbag fault by moving the seat, but I can guess it's due to the connector not fully making contact.
    I would try disconnecting and then reconnecting the under seat connector a few times and making sure it's well connected and secure. You may want to disconnect the battery and wait a few minutes for any capacitors to discharge before doing this though.
    Can't see how the airbag fault is related to the blower not switching off - could be a stuck relay behind the glovebox that operates when the blower on full.
    Jun 2007
    Edinburgh
    Thanks guys. I will check it out over the weekend.
    Jun 2007
    Edinburgh
    Quote Originally Posted by VauxVeteran View Post
    Just managed to get the glove box off. Is it the black box that is attached to the fan casing. Dont see an heat sink anywhere and there is a black box just to the right of the fan casing.
    Nicking Ya Dinner.
    Quote Originally Posted by Milden View Post
    Thats generally where they are located mate, on most cars, maybe they don't have the sink on them anymore, other than that I can't help much, but that is what is causing your problem, get it tech 2'd to confirm.
    Regular Member Ian's Avatar
    York
    check out this thread for details of how to change it.
    http://forum.vectra-c.com/showthread...gulator&page=3
    Usually though the off position still operates, it just that it doesnt wortk on fan positions 1,2 or 3.
    Jun 2007
    Edinburgh
    Thanks for the link, will have another scout around tomorrow.
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Check the relay on the left hand side too (bottom of A pillar area. When blower on 4 it clicks on.
    Regular Member djr69uk's Avatar
    Midlands
    yeah the air bag light is probably signalling seatbelt pre-tensioner failure. it is a common problem on fords too although on the ford the light flashes a different number of times depending whether its an airbag or pretensioner failure. as mentioned disconnect and reconnect the pretensioner connectors under the seat and that should sort that one out.
  1. heater blower
    By Pete Kincaid in forum Vectra C / Signum Car Chat
    Last Post: 24th November 2017, 18:02
  2. Heater / Blower Not Working Properly (2006 Vectra 1.8)
    By bigboynigs in forum Electrical & ICE (including SatNav)
    Last Post: 4th January 2013, 16:31
  3. Heater / Blower Fan
    By chris2464 in forum Bodywork & Interior
    Last Post: 5th January 2012, 13:30
  4. wanted heater blower motor vauxall vectra c
    By Les45 in forum Vectra C / Signum Car Chat
    Last Post: 24th May 2011, 08:21
  5. heater blower
    By bootneck85 in forum Electrical & ICE (including SatNav)
    Last Post: 18th April 2011, 00:40
vectra c glovebox relays
vectra c heater fan
blower motor for vectra 2005
were is the fuse for heater blower in a vectra c
