Thread: 55 plate SRi woes
    Regular Member djr69uk's Avatar
    Midlands
    Default 55 plate SRi woes
    6 months of ownership and I'm getting hacked off with the vectra despite the fact i love it to bits!
    -3 x limp home mode (cured when cleaned EGR)
    -2 x bulb failure light - but disappeared the next day... !?
    -rear wiper not working
    -blower works on 1 and 4 but most of the time not on 2 or 3
    todays new problem... 'external in' cutting in briefly and muting my CD whilst i'm listening to it... even though there isn't a phone in the cradle!!
    is there some sort of central control unit that could account for the wierd problems with bulbs, wiper, blower and anything relating to the inputs on the radio!?
    ... or does my veccie have CANBUS gremlins?!
    Regular Member LJ sxi-nav's Avatar
    Winchester
    blower only on 1 and 4 sounds like the resistor pack problem. search resistor pack and you should find some useful info.
    Full Member Big Sig's Avatar
    Bulb failure, may actually be a dodgy connector on a bulb. have you checked them???? Although thats not really a fault with the car at this stage.
    Yorkshire
    The lamp failure could be a lamp on its way out.
    The filaments weld there self back together when they arc but this only lasts a short while. If you lightly flick the lamp with your finger it will usualy break the faulty lamp.
    Midlands
    i thought the heater problem might be the resistor pack but it's intermittant. would have thought the resistor pack would fail and it would only work on 1 & 4... not sometimes on 2 & 3 as well?
    ok... i'll check the bulbs out.
    the 'external in' one is a bit wierd. perhaps i should check behind the dash for water ingress! might explain some of the problems...
    Midlands
    ...and then driving back home last night my oil light comes on. i panic... pull over and check the level. it's at the max mark!
    What would cause that if the level is fine? Drop in oil pressure?
    ...or Gremlins!?
    gremlins... it'll be a dodgy oil level sensor in the sump..
  1. More AC Woes...
    By Munkey in forum Vectra C / Signum Car Chat
    Last Post: 1st August 2012, 17:59
  2. new car woes
    By dunkf in forum Engine & Drivetrain
    Last Post: 11th July 2011, 11:55
  3. New car woes
    By hack in forum Vectra C / Signum Car Chat
    Last Post: 3rd November 2010, 19:58
  4. Mot woes!!
    By the-wizard in forum Vectra C / Signum Car Chat
    Last Post: 26th July 2010, 10:14
  5. air con woes
    By chinky in forum Vectra C / Signum Car Chat
    Last Post: 29th July 2008, 19:23
