Thread: slipping auto gearbox?
    Sussex
    confused slipping auto gearbox?
    not sure if its normal or not, but if i give my car some welly, the gears go from 1-2 fine, but when it comes to go from 2-3, it seems to feel like its 'slipping the clutch' for a second or 2.. is this normal, or am i going to have to get my god dam wallet out AGAIN???
    CURLY
    Sussex
    no-one else got this on theirs then?
    if you mean it takes a moment to change then yes, it's not instantanious...
    the condition of the fluid in the box will tell you a great deal more about whats going on inside the unit.....
    Regular Member Darryl2.2DTI's Avatar
    Oct 2007
    Kilmarnock, Ayrshire
    Vehicle : Vauxhall Vectra C
    Trim : LS
    Engine : 2.2 DTI
    Mileage : 106000
    i recon ive a similar problem. its as if the clutch slips at hi revs. mines has always done this but its second hand. car changed gear but revs slide up as its doing so.
    mine flips it revs up during gearchanges as well... something to do with still having the power on..
    Sussex
    if i hoof it away from the lights it changes from 1st to 2nd like a manual, but when it changes fron 2nd to 3rd its as if the clutch slips for a second or two, then 3rd to 4th and 4th to 5th its fine again..
    i've checked the oil and its pretty clean red colour at the right level with no sign of pinkyness, so thats ok.
    maybe its normal?
    CURLY
    Brighton
    Query?
    Are you using the full kickdown when you, "Hoof it"?
    That could be the problem, the gearbox does not understand what gear it should be in, whilst changing from 1st to 2nd will be fine, whilst Kickdown is still there, it will behave as if it wants to change back into 1st, which it will not, this will delay its' changing into 3rd.
    If I use full kickdown when accelerating from start then this does a similar thing to what you say.
    If however you push the pedel to the point of kickdown, it will accelerate properly, it will give a small timing break between gear changes, but should not, "Slip" as you say
    Not sure if this helps
  1. F23 auto gearbox oil
    By Paddy in forum Engine & Drivetrain
    Last Post: 12th March 2011, 21:56
  2. auto gearbox?
    By no1golfer in forum Engine & Drivetrain
    Last Post: 24th July 2009, 22:09
  3. auto gearbox
    By cerbrious in forum Engine & Drivetrain
    Last Post: 17th July 2009, 20:04
  4. 3.2 auto slipping clutch / torque convertor ?
    By poves in forum Engine & Drivetrain
    Last Post: 23rd August 2008, 21:01
