Results 1 to 10 of 16
Thread: Suspension 'CLUNK'!
    Regular Member John3v36's Avatar
    NI
    Default Suspension 'CLUNK'!
    Every now and again i hear a clunk from my front left suspension only going over sharp bumps or turning the odd corner- anyone else heard this?? and know what it is??
    West
    First things to check for are cracked spring or warn drop link, imo...
    NI
    are they pricey or hard to fix?? DIY job or not??! is this common??
    West
    They are both common, hopefully it will be just the drop links mate & the are under £15 each at vx & an easy job i'm told.
    What motor do you have btw...?
    Jul 2006
    Drop links are even cheaper from places like EuroCarParts - about a fiver each
    NI
    mines a 2003 2.0dti saloon!! i hope its only that and not anything else! ill have to get her up on the ramps and/or jack her up and have a peek - weathers to be bad here this weekend too
    East Midlands
    Quote Originally Posted by John3v36 View Post
    Another culprit is the upper rear suspension arms,these can be checked whist the car is on the ground,mine had similar clunks.
    Grasp the top of the rear wheel at 10 oclock and 2 oclock and try and push and pull the wheel backwards and forwards ,if you feel a clunk whist doing this maybe 10mm to 20mm of play,its odds on the above,don't panic to much though ,cheapish and easy to fix,since doing them on mine no more knocking ahh the bliss.
    Regular Member Matt8's Avatar
    Cheshire
    I've got this on my 06 vectra cdti. Been back to Arnold Clark/Masterfit many a time (warranty) and they say there's nothing wrong.
    It gets quite severe over bumps or sometimes while turning corners. What are drop links? Could it be anything else like CV boots, or a wishbone somewhere? It's a teeth-grinding noise eh?
    Regular Member JuzzyD's Avatar
    Jun 2006
    Somewhere...
    I had a clunk/knock going over speedhumps and it was the anti-rollbar bushes
    Maida Vale
    Check out this thread for alternative suggestion:
    http://forum.vectra-c.com/showthread.php?t=55613
  1. Big Clunk
    By Ben_ in forum Suspension, Wheels & Brakes
    Last Post: 2nd January 2011, 15:03
  2. i have a clunk
    By solorider in forum Vectra C / Signum Car Chat
    Last Post: 1st March 2009, 22:03
  3. Suspension clunk??
    By Ian T in forum Suspension, Wheels & Brakes
    Last Post: 14th July 2008, 14:53
  4. Suspension Clunk Solution/s Recap
    By installer in forum Suspension, Wheels & Brakes
    Last Post: 22nd April 2008, 08:45
  5. Clunk!
    By B19CBB in forum Suspension, Wheels & Brakes
    Last Post: 21st January 2008, 18:30
vectra c suspension clunk
